It's time to move my Jet 10" cabinet saw (about 500 lbs). I'd like to lift it into the moving truck from the ground with a cherry picker but can't find anything on the saw that looks like a safe strapping feature. Anyone tried this? Plan B is to put it on a furniture dolly but those are pretty tippy.
Lifting a Table Saw Question
To pick up my Unisaw I wrapped a sling around/under the table and used my chainfall....worked just fine.Last edited by BigMike782; 04-27-2014, 08:12 PM.
From what I've seen, the table, trunnions, motor- all the heavy stuff is part of the table or hanging from it. I think you could strap around the table and lift it like that.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
I've opted to first try rolling it up the ramp on a pair of furniture dollies, somewhat on it's side. If that fails the table will have to handle the load. I have a 200lb foot kicker potter's wheel bench to move too and that has no support at all, so it will get the same treatment.
500lbs? Thats a beast. Ive moved some top heavy stuff and its not fun. I think the saw is prolly top heavy? Nice table? Unlike some machines she can be tilted and placed on the table with a moving blanket under the table. Get her upside down and she might be more manageable? Then the dolly will make it a easy process. JR
The 4 large fasteners (usually) that hold the table to the saw are more than ample to support the weight of the saw.
I used to worry about removing a big block V-8 and automatic transmission using an engine lifting eye bolted to the carburetor mounting flange of the intake manifold. Four 5/16" studs don't inspire a lot of confidence at first glance but the strength is definitely there.
They should make a lift gate a standard on those moving trucks, I mean really, not everyone has a loading dock at either end of a move.Home, down in the valley behind the Red Angus
Bad Decisions Make Good Stories
Boy, I'm glad my 10" table saw only weighs 20 or 30 pounds. Aluminum and a light weight motor. I just pick it up and put it down where I want it. And I have a bad back.Paul A.
s
Golden Triangle, SE Texas
When I've had to do this (without a forklift) I have removed the table and just used a hand truck to move each piece up a ramp into the truck. Or, if the right equipment is available, a pair of straps under the table can be used to safely hoist it.
What I ended up doing is: All the table extensions, rails, and riving blade came off, I used the cherry picker to put the base on a furniture dolly, then used the lift to tip it gently on it's side with the table edge on a second dolly. The strap ran parallel to the blade arbor and there was enough room between the cabinet and the table to fish it through. My wife and I rolled it up the U-Haul ramp, and because the truck is on an inclined driveway, it pushed me all the way to the front of the truck deck. I think some previous possibly unhappy renter sprayed the inside deck with WD40. No traction at all for my deck shoes. Wish I'd have learned that by loading a box of pillows
I used the same technique to load my radial arm saw.
