Alistair Hosie
05-14-2004, 07:37 PM
I am just starting work on my shop (machine shop) under my carport I will need to move the machinery which is at present at the front of my carport up to the back when I make a platform for them.
I told you before but in case you forget my current floor of the carport slopes very badly about sixteen inches from front to back so I will make a flat platform to stand the machinery on at the rear while I work on the rest.
I have a lathe and a milling machine one is a ton and a quarter and the mill is about half a ton I figure moving the milling machine should not be too bad but it may be top heavy so I will need to take care I need to move them about ten feet and raise them when done so about four inches onto the back platform any ideas as I am alone might get a little help if I am pushed.any ideas as I don't want to kill myself or anyone else. Alistair
