New throttle bodies for my car
  • sid pileski
    • Apr 2001
    • 2529
    Some of you may recall on my '32 Ford hot rod, I have an 8 stack fuel injection system. Meaning I have an individual throttle body per cylinder. Well, I used a TWM throttle body in originally, but always wanted to make my own, so this winter, I started on that path.
    The following pictures describe the process. The setup was designed in ProE.
    I hope you enjoy. I'll answer any questions you may have.
    Starting with raw parts, fixtures and finished comonents.
    Thanks, Sid
    Made 17 raw bodies.
  • sid pileski
    • Apr 2001
    • 2529
    #2
    continuing:
    • sid pileski
      • Apr 2001
      • 2529
      #3
      Injector pocket:
      Base fixture:
      • sid pileski
        • Apr 2001
        • 2529
        #4
        • sid pileski
          • Apr 2001
          • 2529
          #5
          • sid pileski
            • Apr 2001
            • 2529
            #6
            cross shaft:
            • sid pileski
              • Apr 2001
              • 2529
              #7
              • sid pileski
                • Apr 2001
                • 2529
                #8
                A lot of other work went into these, but I didn't photo everything. Spring was coming and I had to get going!
                • millwrong
                  • Apr 2008
                  • 165
                  #9
                  As always, stunning work! The fourth picture;what am I looking at? Appears to be a boring bar with spring?
                  • sasquatch
                    • May 2006
                    • 4957
                    #10
                    Wow Sid,, great piece of work, real nice, and great photos.
                    • sid pileski
                      • Apr 2001
                      • 2529
                      #11
                      Yes- A boring bar. I had a little chatter in the bore, so an old trick, wrap the shaft in soldering lead. The lead dampens the vibration of the bar, resulting in a
                      smooth bore.
                      Sid
                      • sid pileski
                        • Apr 2001
                        • 2529
                        #12
                        Thanks, Sasquatch!
                        • sid pileski
                          • Apr 2001
                          • 2529
                          #13
                          Oh, yea. Here is a picture of the jaw I made to hold the bodies for various setups.
                          • TGTool
                            • Aug 2005
                            • 3616
                            #14
                            Beautiful work. And a nice looking machine. What is it that I"m just seeing a bit of the head in on post #4 last photo? KT rotary head?
                            • sid pileski
                              • Apr 2001
                              • 2529
                              #15
                              The mill is a prototrak k3. I program at the machine or use cambam if I need to.
