View Full Version : Balancing act
quadrod
06-28-2014, 09:11 AM
http://www.break.com/video/ct-scanner-opened-up-at-full-speed-2643696
ZINOM
06-28-2014, 09:35 AM
Not knowing what one of those normally looks like while in operation I found it kinda boring....here's one minute, 18 seconds of goodness:
https://www.youtube.com/watch?v=1VaYTkn2aSg
John
quadrod
06-28-2014, 07:06 PM
I was just wondering what it takes to balance that much weight to make it run silky smooth.
Frank Ford
06-28-2014, 08:08 PM
OT, alright, but thanks for posting that - I've spent more time than I'd like inside that whirling donut! Never thought much about what was going on around me.
CarlByrns
06-28-2014, 11:24 PM
I had some minor surgery done in one of those things. Now I understand why the room was so cold.
boslab
06-29-2014, 12:37 AM
Looked like a Phillips CT scan, whats fascinating is the slip rings that get all the power to the tube cooling the thing and signal out, i understand that the high voltage generator is moving otherwise there would be a 60Kv slip ring, bet that would arc a bit!
MRI units are fascinating too, went to the factory in Holland to see them, the torus was powered up after filling with liquid Helium and the guy got a big ring spanner on a rope, chucked it at the thing and it pulled the rope horizontal, must have been a regular demo as the end was shackled to the wall, tthe pull on the rope was quite impressive.
Mark
flylo
06-29-2014, 01:34 AM
Had 14 MRI's last year, glad (hope & pray) that craps over but now my wife has some very major stuff coming up. Sucks to deal with a system where all they want is your money & insurance.:mad:
plunger
06-29-2014, 03:30 AM
Thats amazing . My lathe dances like that washing machine if I use my 4 jaw on irregular work. Now one can see why it costs so much. The first ct scanner was co invented by a s african. Shows you that some good things can come from the african continent
Jaakko Fagerlund
06-29-2014, 04:15 AM
Nothing special, just te right amount of counterweight in the right location. And that thing is revolving quite slow, so even a basic static balancing would probably work fine enough.
