View Full Version : Standard modern 1334 oil leak
onewoodworker
07-07-2014, 07:56 PM
Hello
I have a standard modern 1334 lathe that is spraying oil from behind the chuck.
The oil drain hole is not plugged.
Looked on schematic and don't think it's the #244 O ring.
Anybody have same issue with this model lathe and what you did to correct this problem.
Thanks
