View Full Version : Busted scerw extraction may be handled......
08-01-2014, 08:09 PM
Went a bit farther afield for tag sales, and found a few goodies that I can use, including this..... smallest size, for 1/4-20, is missing, but I should be able to get one someplace..... 20 bucks the lot, in the die-cast metal box...(snazzy, probably collectible, as if I care).
http://img.photobucket.com/albums/0803/jstanley/old%20tools/blue-pointextractors2_zpsb0853851.jpg (http://smg.photobucket.com/user/jstanley/media/old%20tools/blue-pointextractors2_zpsb0853851.jpg.html)
http://img.photobucket.com/albums/0803/jstanley/old%20tools/blue-pointextractors1_zps6589feb4.jpg (http://smg.photobucket.com/user/jstanley/media/old%20tools/blue-pointextractors1_zps6589feb4.jpg.html)
I understand these are the best available for the purpose, so the problem may be handled.... at least for these sizes.
PStechPaul
08-01-2014, 08:34 PM
I would have thought the drills should be left-handed, or is it only the flutes that are RH?
Looks like a splined shaft that is pressed into the hole to get a grip for extraction?
Seems like a nice set, well worth the $20.
08-01-2014, 09:02 PM
Still available from Snap on,$120/set and individuals forsale also.
http://buy1.snapon.com/catalog/item.asp?item_ID=630634&group_ID=675450
They do work good,they also make the second best pipe extractors.
08-01-2014, 09:09 PM
The drill is kind of beside the point. It just makes a hole for the splined rod to be pounded into, and then the nut-like devices on the left turn the splined shaft. So the handedness is no issue. I suppose LH they might extract the screw all by themselves. I could get LH drills for it if I wanted, the drills are standard sizes.
The things at bottom are drill guides to make sure you go down central and not out into the threads.
next time I have a busted screw, I'll give it a shot, and report back....
Rosco-P
08-01-2014, 09:11 PM
Yuup! You need to drill a left handed hole for the screw extractor to work.
Don Young
08-01-2014, 09:34 PM
I have had that same exact set for at least 50 years and it has removed a lot of screws. If you can drill completely thru the stuck screw it rarely fails. Of course, the usual aids like penetrating oil, heat, and vibration still help. I don't know who actually makes them but I have seen the same set with the Ridgid name on them. The two smaller ones tend to get damaged so keeping spares is a good idea.
RichR
08-01-2014, 10:09 PM
I've got the same set, cast metal box and all, except mine says Ridgid.
GEP
08-02-2014, 09:05 AM
You state the second best extractor. In your opinion whats the best extractor
08-02-2014, 10:20 AM
The splined removers say Ridgid, so that would be Ridge Tools, div Emerson (or maybe Emerson sold them)
