View Full Version : Central Machinery pneumatic riveter
davidwdyer
08-06-2014, 02:04 PM
I need help with a Central Machinery pneumatic rivet gun.
Please, no need for disparaging Harbor Freight tools. Instead, help me with the problem. It will see limited use.
I got the thing open, following the instructions, to fill "to fill with hydraulic oil (unspecified) to 'the top of the housing.'"
Except I don't know what "hydraulic oil" they mean or exactly what "top of housing" means.
Does anyone have one of these and could help me?
George Seal
08-06-2014, 03:25 PM
Automotive Parts house Jack Oil
any light weight oil will do
Have not used one With air intake pointed down fill with oil until it come out the fill hole. Replace plug good to go
MaxHeadRoom
08-06-2014, 03:26 PM
If this a manual, or semi-manual unit, and there is nothing in the reservoir now, one source would be ATF.
available any auto parts store.
"top of housing" I would guess as up to the filler hole?
Max.
J.Ramsey
08-06-2014, 04:17 PM
Should be ready to use right out of the box,won't need any oil replacement until it quits working, usually around 2-3,000 rivets.
When the time comes hydraulic jack oil or power steering fluid will work fine.
MrSleepy
08-06-2014, 04:21 PM
Jack oil is usually a ISO32 lightweight hydraulic oil.
eg... http://www.amazon.co.uk/gp/product/B00B6BWTQU?*Version*=1&*entries*=0
Rob
mixdenny
08-06-2014, 06:55 PM
That's what the instructions for mine say also. It works fine, guess it's already filled. Dennis
randyjaco
08-06-2014, 07:29 PM
I used pneumatic oil in mine and it works fine.
Randy
davidwdyer
08-06-2014, 07:35 PM
I guess I'll have to see where I can find some oil here. It 's not like the States where you can find what you need easily.
But I'm sure there is some jack oil somewhere.
Thanks a lot for all the advice folks.
KJ1I
08-06-2014, 07:42 PM
Download a copy of the "current" instructions: http://manuals.harborfreight.com/manuals/93000-93999/93458.pdf
They state "Hold the Air Cylinder (29) upside down, and pour in hydraulic oil (not included). The fill level should only reach the top of the Frame (15)."
That means hold the part with the riveting head upside down, and add enough oil to just come to the top of the lip beneath the threads. Then reassembly. As stated elsewhere, since this is a low pressure application, jack oil, power steering fluid, or any light weight motor oil will work.
superUnknown
08-07-2014, 02:57 PM
power steering fluid or automatic transmission fluid for your car will work nicely, unfortunately, it might cost more than the riveter itself.
