View Full Version : 4140 Prehard, RC34: bandsaw cut or no?
Arthur.Marks
09-04-2014, 10:44 PM
I know it can be turned, milled with HSS--though carbide is very much recommended. But can stock be cut to length on a horizontal bandsaw with a good bimetal blade? Just wondering as I don't have a true abrasive saw. I can butcher it to rough length with an abrasive disc in my die grinder, but the bandsaw would be far more accurate and efficient.
caveBob
09-04-2014, 10:46 PM
I've cut 4140PH no problem with a smaller table-mounted portaband, bet you'll do fine.
PStechPaul
09-04-2014, 11:14 PM
I don't have experience with the pre-hard, but I'd first try cutting it at least part way with a hacksaw, and see if the blade stays sharp or dulls quickly. Much cheaper than a bandsaw blade. And you can just finish the cut by hand and get an upper body workout. :rolleyes:
lakeside53
09-05-2014, 12:28 AM
Bandsaw is fine. Slow speed, and don't be too wimpy with feed or it will work harden. Use coolant if you can.
SGW
09-05-2014, 06:26 AM
Should be no problem.
browne92
09-05-2014, 09:41 AM
Is pre-hard the same as heat treated? I've cut 4140cfht on my band saw several times no problem.
Toolguy
09-05-2014, 11:00 AM
I've done it lots of times. A good bimetal blade will walk right through it. Rc 32-34 isn't very hard. Pay attention to posts above about slow blade speed and coolant if possible. It will cut OK dry but coolant is better.
cuemaker
09-05-2014, 11:01 AM
This is the correct answer. My shop cuts this all day long. Normal blades work also. I also cut this stuff with my portaband at home when since i get the material for free......
Arthur.Marks
09-05-2014, 02:08 PM
Thanks for the info, everyone! Very helpful!
