View Full Version : Shade Tree Blanchard Grinder
Old Hat
09-14-2014, 01:53 PM
Now can I quallify as a Home Shop machinist?
He needed his Pickup Truck, and don'tcha know it rt frt caliper was seized.
E R time I, got it all appart, while he went for calipurs, and I thought "why not",
Let's try a little trick, as he doesn't have time for rotor-work.
7" side grinder to the rusted inner face, where pads don't make contact.
Bout 180 rpm latter I went to the outter edges.
.003 T I R... Offset from the .003 T I R of the worn in area.
Not bad for eYe-bAll work.
http://i126.photobucket.com/albums/p92/swadge/I%20did%20it%20My%20way/0913141603_zpseaf38d44.jpg (http://s126.photobucket.com/user/swadge/media/I%20did%20it%20My%20way/0913141603_zpseaf38d44.jpg.html)
http://i126.photobucket.com/albums/p92/swadge/I%20did%20it%20My%20way/0913141604_zps46e83b47.jpg (http://s126.photobucket.com/user/swadge/media/I%20did%20it%20My%20way/0913141604_zps46e83b47.jpg.html)
Toolguy
09-14-2014, 02:03 PM
Nice job. Whatever it takes to git er done!
Old Hat
09-14-2014, 02:06 PM
Thanks, went for Jalepino Poppers with it, and pads seated in Pronto.
Next time it's my car, I'll try a 100% clean-up just for Kiks.
digger_doug
09-15-2014, 03:24 PM
I mounted a H.F. 6" cross slide vice, and clamped a air die grinder in the vice,
with a stone, 1/4 h.p. motor on a board sitting on the ground, v-belt looped around rotor.
Old Hat
09-16-2014, 02:22 AM
Sounds fun!:cool:
Take a pic next time!
oldtiffie
09-16-2014, 06:32 AM
Good post OH - many thanks.
In its simplest form a Blanchard grinder has segmental insert grinder inserts and it has a vertical spindle with the work rotating on a magnetised chuck.
The spindle is slightly off-set from vertical to the chuck.
The Blanchard grinder is in effect a grinder version of a normal fly cutter - which can cut a very accurate flat face - simple as that.
https://www.google.com.au/?gws_rd=ssl#q=blanchard+grinder
willmac
09-16-2014, 12:40 PM
I would go with you up to that statement, which I think is misleading.
A flycutter is essentially a single point cutter. A Blanchard grinder effectively has many cutters which are arranged in a plane . The cutting action is quite different and this matters.
Old Hat
09-16-2014, 01:03 PM
Maybe he meant "The Blanchard grinder is in effect a grinder version of a normal face-mill".
But not realy either.
Blanchard work done correctly settles downward and cuts uniformly allong the entire
faces of the stones.
A face mill cuts only "in-plane" advancing latterally.
Blanchard grinding is A Bird all it's Own.
oldtiffie
09-16-2014, 07:45 PM
I take your point Bill as it I did say it was "effectively" as opposed to - saying - "actually".
Much the same was as an end mill cutting on its end is effectively a multi-toothed fly-cutter.
