View Full Version : Hemingway Kits adds an adjustable flycutter
tlfamm
10-04-2014, 09:15 PM
Intro price: 25.75
http://www.hemingwaykits.com/acatalog/Adjustable_Flycutter.html
oldtiffie
10-04-2014, 10:29 PM
Nice job.
I've had several occasions to deal with HK (UK) from here (AU) and they were first class from order to receipt here - and all nice jobs.
You can also use a boring head for the same purpose if you like - if you have a boring head.
loose nut
10-05-2014, 07:20 PM
It's a trepanning tool being used as a fly cutter.
burdickjp
10-05-2014, 07:51 PM
Are you sure your doctor isn't poking holes in your head with tool bits instead of ice picks?
Paul Alciatore
10-05-2014, 11:30 PM
What's the difference?
loose nut
10-06-2014, 01:29 PM
A trepanning tool is generally used to cut large diam. holes in sheet metal or somewhat heavier metal, not so much for skulls. That's a different type of trepanning tool. Flycutters are for milling, again, not for skulls. You can, as shown, use a trepanning tool for flycutting but it will be flimsy at best compared to a proper flycutter.
