How would one make a part like this one in the picture. Meaning how would I cut the teeth? I will make a cut with a thin slitting saw to make the vertical face of the tooth. It will leave a small land at the base which will be no problem. Then rotate the head of my mill to the correct angle and use an end mill to cut the long slanted face.
I was just wondering how to make this tooth form if it would be necessary. I could dress a grinding wheel to the correct angle and do it that way maybe but other than that I do know how to make the tooth profile.
Is it possible?
Is it possible?
