View Full Version : Where to buy.....
lakeside53
11-18-2014, 10:45 PM
Drilled bolts for slide gate wheel axles. I need 5/8 by about 4-5 inches. The type where you put a zerk on one end and the grease gets to bearings via a central radial hole. Don't want make them... Tired of replacing wheels and bearings every couple of years [unpaid service guy for the community]
Looking for supplier not ebay lisitings.
Trailer guys call them "wet bolts".
Sort of like this :
http://www.ebay.ca/itm/14-KIT-3500-Trailer-Axle-Spring-Shackle-Grease-Type-Eye-wet-Bolt-9-16-x-3-/290652618163
11-18-2014, 11:10 PM
There are 5/8x5" on this page $34/pair
http://www.4wd.com/Jeep-Lift-Kits-Jeep-Lift-Kits-Suspension/Greasable-Shackle-Bolts.aspx?t_c=1&t_s=101&t_pt=8247&t_pn=W%2fI90310
lakeside53
11-18-2014, 11:23 PM
Thanks! might be workable.
I just found similar on McMaster (of course!) but not 5/8. http://www.mcmaster.com/#grease-bolts/=unnbsx
I'd like to find a page listing of the shackle/spring wet bolts.. grumble ;)
Willy
11-18-2014, 11:38 PM
Here's another source. 5/8 x 5 $7.33 ea.
http://diy4x.com/cart/index.php?route=product/product&keyword=greasable%20bolts&product_id=132
Try some of the local shops that do automotive, trailer, and truck leaf and coil spring work. Seems to me I've seen them up here in pay-through-the-nose Kanuckistan in that size for around 5 bucks ea. Irregardless they should be available locally.
lakeside53
11-19-2014, 12:40 AM
That actually helps a lot.. now I use the words "greasable bolt"... I get a lot more results.
