View Full Version : OT. Ironing machine doesn't get hot enough
Black Forest
11-23-2014, 05:18 AM
My wife says her ironing machine doesn't get hot enough. This is the type with a 6" roller that you feed the clothes into. There are three elements. I have posted on here before about a part that was broken.
So where do I start to trouble shoot this machine? How can I check each element to see if they are working correctly? They all get too hot to touch!
What pictures would you need to help diagnose the problem?
_Paul_
11-23-2014, 07:09 AM
You mean you dont do the ironing? ;)
RichR
11-23-2014, 09:25 AM
Hi Black Forest
Use one of those clamp on Amp meters to measure the current and compare the reading to what's written on the specifications tag on the iron.
Rosco-P
11-23-2014, 09:35 AM
Accidently plugged it into the 110vAC outlet again?
