View Full Version : What should I do with this old girl? (HaRo H2Y grinder)
Darrp
11-26-2014, 01:20 PM
I went to an auction to buy a lathe in August and they had this old girl there, the auctioneer said she would be going to the scrap yard if nobody bought her. I couldnít let that happen so I took her home.
Itís a HaRo H2Y w/ a 600v motor.
I am in the process of building a 240v RPC w/ a 600v transformer and for the new lathe, so I eventually get the grinder running with that.
I really donít think I need a grinder, although I could use a surface grinder.
What would you guys do?
-Darren-
http://i773.photobucket.com/albums/yy16/darren1911/IMG_9285_zpsea8df945.jpg (http://s773.photobucket.com/user/darren1911/media/IMG_9285_zpsea8df945.jpg.html)
http://i773.photobucket.com/albums/yy16/darren1911/IMG_9289_zpsa034e9ed.jpg (http://s773.photobucket.com/user/darren1911/media/IMG_9289_zpsa034e9ed.jpg.html)
Daveb
11-26-2014, 03:29 PM
Sharpen your tools and cutters with it. You could do with a few attachments to make the job easier but you can do a lot with a small swivel and tilt vise.
It's also capable of surface grinding, depends on how big the items are that you want to grind.
If you were a bit closer, I would be happy to take it off your hands.
Darrp
11-26-2014, 06:24 PM
Dave if you were closer I would give it to you for what I paid for it, and it wasn’t much!
Darren
Daveb
11-26-2014, 07:04 PM
Ha ha. Thanks.
I'm sure there will be someone on this forum who's been looking for one of these. It appears to be in decent condition.
macona
11-26-2014, 07:20 PM
Sell it an buy a whole lot of sharp tools and cutters with the money.
duckman
11-26-2014, 08:26 PM
Boy would I love to have that I've just been hired to sharpen chipper knives , 4 double edged knives per set , any where from 2 to 10 set per week.
dp
11-26-2014, 08:43 PM
There's a kind of manual for it here: http://s259.photobucket.com/user/olesteen/library/HARO%20H2Y%20grinder%20manual?sort=6&page=1
There's a short thread at PM: http://www.practicalmachinist.com/vb/abrasive-machining/haro-h2y-grinder-192584/
It looks versatile.
11-26-2014, 08:49 PM
Looks VERY nice. Much nicer than my Greenlee base with a TP grinder as a head. (I had a chance at a disassembled "real" grinder a few years ago, but no place, and no time for the project then.)
What you need is what McGyver showed here some years past.... long thread where he built a multi-angle holder.
Find room. You will find uses. Hardly anything built in Geneva is going to be low quality.
A bit closer and I would come get it!
lakeside53
11-26-2014, 09:24 PM
Set it up to sharpen the neighborhood lawn mower blades!
boslab
11-27-2014, 12:04 AM
Looks a nice tool and cutter grinder to me, also dead useful as a giant bench centres for measuring stuff
Mark
Alistair Hosie
11-27-2014, 08:02 AM
If you do sell it don't forget to send the poppy to your old pal BIG AL LOL. Seriously that's a nice piece of machinery.I could think it would be snapped up on ebay.Why not try it ! you might get a good surprise.Alistair
Darrp
11-27-2014, 01:11 PM
dm, When and if I get it up and running you are welcome to swing buy and use anytime you want. ;)
It looks versatile.
dp, thanks for the links, it did come with it's own manual... although a little tattered.
JT, That is something to concider, but I really don't know how much I would use it. Almost everything I have is carbide, although I guess I could get the right stones.
Or even mine ;)
Mark
boslab, That's what I thought, the table is great for something like that.... I was even trying to think of a way to adapt it to flute barrels.
BIG AL, I guess I could try, but most people in the States shy away from Canadian sellers, or maybe it doesnít come up in the searches. About 10 years ago I watched and bought a nice 6" or 8" (don't remember) rotary table. Nobody bid on it and I got it for $80 ... I drove over and picked it up from a guy in the city.
oldtiffie
11-27-2014, 10:19 PM
Note that it is set up as a round tool sharpener - end milling cutters, reamers etc. as well as horizontal milling machine cutters - albeit shown as ready for a mandrel too - all between centres.
Darrp
11-30-2014, 02:47 PM
So I have been looking at it and thinking... and thinking... Would a new wheel be all it takes to turn this into a surface grinder?
redgrouse
11-30-2014, 06:31 PM
Hi Darren, well whatever you do it will never be as good as a dedicated surface grinder, they are a different machine and built to do the job intended, however if you fit a suitable wheel it will work as a surface grinder but will not be as accurate. A good surface grinder plus good operator will work to a few tenths limit, a cutter grinder will not do this for you but how accurate do you want or need to be? It will work to a lot less than 0.001" limit if used with care.
I have an ageing Boxford that is really a tool and cutter grinder but was sold as a combination machine doubling as a surface grinder and it works well enough for my requirements, I can keep to less than 0.0005" tolerance on thickness i.e. Surface grinding
For the small cost of a suitable wheel I would try it, a magnetic chuck would also be a wise investment should you decide to keep the machine.
Just my thoughts good luck John
11-30-2014, 06:33 PM
All it takes is a diamond cup wheel to get going doing carbide.
For reamers, end mills, etc you need a tooth rest, no problem to make.
yes, it will do surface grinding, but not as well as a purpose-made surface grinder. Depends on how the table ways and travel are.
Darrp
12-01-2014, 12:45 PM
Hi John, Thanks for the info, I think I will try it. Right now the only 2 things I want to do are an old mill drill table and a tilting table that has seen too many miles. I was thinking I would use the clamp set for now. The only time I used a surface grinder was in trade school in the '80s and it had auto feed. I guess that I will have to manually feed this one. When I stuck my head under the table the feed system looked like ball bearing and cable feed. ĖDarren-
J-Tiers, I only have carbide tooling so maybe you are right I should start sharpening. There were a few extra rests with it, I will take a closer look. Thanks...
Darrp
12-01-2014, 01:05 PM
Gee, it may be easier than I thought to surface grind with the HARO, I found this thread on a google search
http://www.practicalmachinist.com/vb/general/haro-10-tool-cutter-grinder-243817/
And that led to this brochure;
http://www.harotechnologies.com/pdf/haro_baseline_usages_examples_en_20140909.pdf
I have to increase the service to the machine shop to 100A and then finish the RPC for the new lathe (Kinwa - Chin Hung) anyway, so when I get the 600v into my machine shop I will move the grinder in and get her going.
Thanks for all the help guys!
12-01-2014, 09:02 PM
Sheesh... and I thought "chinglish" was bad. Whatever they meant by "Strawberries", I do not know.... maybe some form of "burr".
That Haro brochure is worth a look-over, if only for the fractured "Binglish". And the collection of pictured non-obtainable-for-a-reasonable-price accessories.
mitsue
12-02-2014, 08:15 AM
If you need you can use my 8x24 Brown & Sharpe surface grinder. Im in west Edmonton.
Darcy
pm or email me for contact info
