View Full Version : Tool insert help
mcat1234
11-28-2014, 04:00 PM
with my lathe, I got (1) tool with a small insert. the insert measures approx. 10mm x 6mm. (diamond shape).
the insert broke. there are no markings on the tool itself. how do I know which is the correct replacement?
Below is the url for inserts that look the same. thanks for helping
http://www.ebay.com/itm/Lathe-carbide-inserts-tool-holder-DNMG-432E-/301409970895?pt=BI_Tool_Work_Holding&hash=item462d6f2acf
sch
11-28-2014, 05:36 PM
There are several diamond shapes,, you might puzzle through this area on Carbide Depot and see if you can sort it out. Diamond inserts can have several tip angles....
http://www.carbidedepot.com/formulas-insert-d.htm Carbide depot has several other areas of technical information that may help as well.
loose nut
11-28-2014, 07:22 PM
You didn't post a location, it would help others if they new roughly where you are because someone that could help may be near by or know of a supplier that could help you, in your area.
PixMan
11-28-2014, 07:44 PM
Did the insert that broke have a countersink or straight hole? if you have a caliper, you need to measure the length of the cutting edge or otherwise determine size by virtue of the largest "inscribed circle that fits between the four sides.
A please do edit your settings to add your location!
mcat1234
12-02-2014, 05:08 PM
Thanks all. I redid my settings. info was helpful.
