View Full Version : Chuck adapter for Yankee push drill
SGW
12-03-2014, 12:09 PM
My Yankee push drill is one of my favorite tools, but over the years some of the drills for it have gone walkabout. Garrett Wade sells a replacement set of drills for $24.95 + $10.95 shipping, which seems a little steep for 8 small drills.
A saw a YouTube video of a guy who sells a replacement 3-jaw chuck for the Yankee push drill. It replaces the existing chuck and looks pretty good. I tried removing the existing chuck on mine, and it wouldn't budge, so that option was out. Besides, I've got a machine shop in the basement.....
Dremel sells a small 3-jaw chuck (part # 4486) for under ten bucks that looked like about the right size. So I made an adapter.
I measured the screw mount for the chuck as 0.178-40. I screwcut that on one end of a short rod, copied the chuck end of a drill on the other end of the rod, and the result was this:
http://i1338.photobucket.com/albums/o686/sasgw/DSC00466-c_zps648a1a72.jpg (http://s1338.photobucket.com/user/sasgw/media/DSC00466-c_zps648a1a72.jpg.html)
http://i1338.photobucket.com/albums/o686/sasgw/DSC00467-c_zps7374de27.jpg (http://s1338.photobucket.com/user/sasgw/media/DSC00467-c_zps7374de27.jpg.html)
kendall
12-03-2014, 01:48 PM
Very nice! Looks like it will increase bit selection a lot. That was the only disappointment I have with the yankee drills, pretty limited bit selection unless you make them yourself.
I know modern versions are available that use 1/4 hex bits, but I'm partial to the old original Yankee's.
You should make up a few, I'd guess there would be a market for them. No idea how many Yankee drivers I've seen without bits.
topct
12-03-2014, 02:21 PM
The Dremel shaft measures .278x40. Is that the same or close enough for a 7mmx.5 die? I love those little chucks and want to use one on a small home built drill.
SGW
12-03-2014, 04:11 PM
The 7mm looks like it might work (0.2756 vs 0.278), but 0.5mm is about 51 tpi. and that would be way off. You need more like 0.635mm pitch.
