View Full Version : DIY live tooling for the lathe
spinningwheels
12-03-2014, 07:32 PM
I try to build A live tooling With MC 3 for my lathe.
Have a multifix B type toolholder that I use for this.
Think that I need about a 0,75 KW 3 phase motor with a VFD.
The shaft is from a old mill that I took appart some years ago.
Made a block that fits in the multifix , and holds the bearings have to make the part for the rear bearing and than get a motor on it.
Here are the first pics,
http://www.mijnalbum.nl/Foto-7DMKXPNC-G.jpg
http://www.mijnalbum.nl/Foto-OVE7SACI-G.jpg
TN Pat
12-03-2014, 08:25 PM
Now that is cool! That gets the wheels turning. With a good method of locking the lathe spindle, you more or less have a mill there... or at least good milling capability. That's awesome.
spinningwheels
12-03-2014, 08:43 PM
I also have a milling attachment, but that takes me at least 15 minutes to set up. this is a quick change. just for some light milling, and drilling.
Im not sure about the motor i need, want it to be small I,ll quess that a 0,75 KW 3 phase 400 volt ( we have 400 volt 3 phase here in the Netherlands) will do or is that overkill?
1/2 inch ( 12mm) will be about the largest endmills that I use in this, and maby drills upto 1 inch .
remco
PStechPaul
12-03-2014, 09:55 PM
That looks like it would be better used as a toolpost grinder than a milling head, but it might work OK. Perhaps instead you can figure out a way to mount the milling attachment directly to the toolpost rather than replacing it. Then you can still use the lathe spindle for the milling tools, with a wide range of speeds and plenty of power. The only advantage I can see for a milling spindle on the toolpost is being able to hold the work in the lathe chuck and having the ability to use it as a sort of rotary table or spindex. For that, you might be able to mount a small drill press with the base under the lathe, perhaps on a linear slide of some sort to adjust the position of the drilling head. You might even be able to mount the post of a small drill press to the cross-slide and use the lathe controls to adjust its position.
velocette
12-04-2014, 02:36 PM
Hi
This will certainly be useful addition to your lathe for milling flats slots etc.
You can use the various screw cutting gears on a extension fitted in the bore of the lathe spindle and locked with a taper plug and drawbar.
A locking device into the teeth or a worm drive and you have a dividing head for umpteen combinations.
I have this type of setup on a 10X27 lathe and pleased with the results.
Eric
spinningwheels
12-04-2014, 06:31 PM
Made the housing for the rear bearing, found a small 3 phase motor and a VFD ,
http://www.mijnalbum.nl/Foto-VRNAO4JL-G.jpg
vpt
12-04-2014, 10:05 PM
Nice work spinningwheels.
Live tooling adds allot in a lathe especially for odd projects.
What I did was pick up a unimat lathe and just use the headstock in the compound, or on its pole, or what have you. Does some neat stuff!
http://img163.imageshack.us/img163/872/0szr.jpg
http://img41.imageshack.us/img41/9648/excursionfpr015.jpg
Most of my pics don't work any more or I could show lots more.
