View Full Version : I hope the machines like us...
ironmonger
12-10-2014, 01:13 PM
Interesting clip of a laser at work:
https://www.youtube.com/watch?feature=player_embedded&v=D0DbgNju2wE
I hope the three laws of robotics are followed more closely than other laws we enact...
http://en.wikipedia.org/wiki/Three_Laws_of_Robotics
paul
loose nut
12-10-2014, 01:22 PM
So the Chinese will have them deployed by the end of the year.
ikdor
12-10-2014, 01:51 PM
I always wonder how well this would work if the target was made of polished aluminium....
Maybe the people wearing the alufoil hats aren't that stupid :-P
Igor
macona
12-10-2014, 03:33 PM
These work by heating the object till something fails, even a polished aluminum surface will probably absorb 10% of the beam and loose it's surface finish quickly and then it is all over with.
2ManyHobbies
12-10-2014, 04:09 PM
These work by heating the object till something fails, even a polished aluminum surface will probably absorb 10% of the beam and loose it's surface finish quickly and then it is all over with.And 10% of anything with a "mega" prefix gets uncomfortable quick -- in the most general of terms...
Mike Nash
12-10-2014, 06:13 PM
http://farm9.staticflickr.com/8446/7928883010_585169e442_d.jpg
vpt
12-10-2014, 07:25 PM
https://sp.yimg.com/ib/th?id=HN.607995291632665501&pid=15.1&P=0
loose nut
12-10-2014, 08:22 PM
AND if the object is a container under pressure or contains flammable/explosive material.
radkins
12-11-2014, 06:19 AM
What about a mirror surface?
vpt
12-11-2014, 08:22 AM
A laser reflector, use their own weapons against them.
Old Hat
12-11-2014, 08:54 AM
Long long ago, I worked in a shop that had a ? 20 ? station Strippit Fabricenter.
It was the first around here to have a laser cutting station.
They had great success untill they tried to cut out brake-pads from sheet stock
with brass fragments all thru it.
It ended baddly, can't realy recall what all was damaged.
Fasttrack
12-11-2014, 10:25 AM
The Navy is interested in finding less expensive weaponry. Believe it or not, lasers, rail guns, etc are much cheaper to operate than conventional propellant based weapons. Sure, it won't work in every scenario, but the cost to fire a couple of high intensity IR beams is pretty negligible compared with large caliber weapons. That particular laser is one developed by Raytheon and has a range of a few miles. It was designed for taking out UAVs and explosives. As the video shows, the beam was used to detonate munitions/fuel carried by the enemy.
Others on the docket include Boeing's Free Electron Laser for taking down cruise missiles.
