Spent all day in the shop yesterday wrestling with Dolphin CADCAM & Mach3 so today it’s time to hit a couple honey-do’s to reduce the guilt factor.
The top rack on SWMBO’s dishwasher’s been limping along for months with a roller that popped off almost every time it was moved due to a broken axle. Even if the parts were still available I'm sure I'd have to buy the whole rack & both sliding rails.
A bit of stainless rod from an old printer, a quick run on the ORAC using a Mach3 turn wizard gave me a hat-shaped bushing to replace the broken part. The axle was sawed off & sanded flush & a 4-40 sized hole was drilled & countersunk on the back side. It took longer to root around & find a 4-40 c/s stainless screw than it took to do everything else!
