Need to buy a gear cutter (have little experience cutting gears) to make a new pinion for an arbor press.
The pinion has 12 teeth with an OD of 1.875
I used the following formula:
# of teeth +2 divided by OD
(14 / 1.875) = 7.4666666667
Not sure what to get, a 7 or 8 DP cutter ???
And if it don't matter because its too close, and having little experience cutting gears, which would be a more common cutter to get (for later use) if it does not matter.
Tried making my own cutter out of D2 but i have no luck hardening (have tried a few times (MAP gas and magnet check) with different projects and never get the results i want) its too soft and wore on a test cut in 1018.
The new pinion will be made out of pre-hard 4140.
Thanks for any help
_
Thanks for any help
_
