View Full Version : 3-D printed jet engine
oldtiffie
02-25-2015, 06:55 PM
I thought that this topic in the Australian media today may be of interest to some who are interested in 3-D printing.
Sorry about the additional "local" stuff (Australia) but I could not eliminate it.
http://www.abc.net.au/news/2015-02-26/australian-researchers-create-first-3d-jet-engine/6262462
02-25-2015, 11:31 PM
Interesting,I don't see why not,afterall if laser sintering is good enough to produce a fully functional pistol from stainless and inconel there isn't much reason not to use it for an engine prototype.
http://youtu.be/u7ZYKMBDm4M
02-26-2015, 12:06 AM
That's not "quite" your table-top "3D printing"..... It's one of the higher-tech versions.
I suppose though, it is enough to get the media foaming at the mouth about people manufacturing weapons, drones, jet engines, or whatever on their kitchen tables..... Never thinking about the fact that just making the titanium powder (or other metal powder) is a high enough tech process that it is not a common material easily sourced and used by potential malefactors. After that, the laser plus control system etc, is not exactly cheap table-top stuff either. It's a fairly big step from the cheap plastic printing stuff.
I know a few folks who do have laser CNC cutters that they built, but their stuff cannot do that.
oldtiffie
02-26-2015, 12:45 AM
Maybe those (thieving?) buggers in OZ stole it from the Chinese.
It was good timing though with the world's attention on the Australian International Air Show this week.
http://en.wikipedia.org/wiki/Australian_International_Airshow
https://www.google.com.au/?gws_rd=ssl#q=airshow+australia&spell=1
And not a Chinese machine (or any type of) tool to be seen.
Odd/shame that.
justanengineer
02-26-2015, 08:37 AM
Interesting article, but there has to be quite a bit more to the manufacturing process than simply running parts through an RP machine, balancing for one.
JMO, but the article sounds a bit too much like a sales ad bc of all the name-dropping. It reminds me of many of the folks I see weekly, somebody cold-calls and gets an engineer thats semi-open-minded and in need of a coffee break, they make a presentation and suddenly their website has our logo on it with fancy words like "collaboration." In reality I listened to a sales schpiel and have no further interest. OTOH I do give the folks in the article credit for suggesting RP is so much faster than traditional manufacturing methods, when someone makes so bold of a lie I do have to respect their gall (assuming Oz'z manufacturing sector doesnt have ridiculous lead times that is).
rythmnbls
02-26-2015, 09:28 AM
Having built a few gas turbines I would like to see one running before I get too excited. Making parts is one thing, a running engine is another.
Regards
Steve.
Billy Hill
02-26-2015, 09:51 AM
This.
Did you notice the slide sticking on it's way back between shots?
JCHannum
02-26-2015, 11:11 AM
What I never see in these presentations is if there is a need for secondary machining of the parts and what loss there is of the powder used in the sintering process.
The engine and M1911 are very interesting, but are the parts removed from the printer and directly assembled into a functional unit? The fancy balls being printed and removed from the powder leave a mass of unfused material, it it reusable as is or does it require treatment prior to reuse if reuse is possible at all.
It is very interesting, but has quite a way to go before it can do all that is intimated in the press releases.
Rustybolt
02-26-2015, 11:27 AM
Currently they can.
There is a deposition process that was patented by an MIT professor that deposits a vitreous metal-ceramic material that is extremely strong. They've made crecsent wrenches that they can take out of the machine and use.
I would say that there is a long way to go, but the improvement steps keep getting closer and closer together.
Jon Heron
02-26-2015, 02:05 PM
The article is misleading, the technology is not a new "breakthrough" as well as there are some other questionable comments.
I assisted in the installation of the first metal 3d printer in Canada 4 years ago at RIM in Waterloo (right across the road from Raytheon coincidentally).
It also used a laser to sinter the metal in the print head.
They were using it for prototyping their new BB10 tablet and phone cases at the time (before they were released).
Jon
loose nut
02-26-2015, 02:33 PM
Even if there is some secondary machining to do the big advantage is in the internal shape of the compressor and turbine blades. The fact that a blade could be made with the minimum internal structure instead of a solid would greatly reduce the weight of the engine. Cooling holes could be made more intricate and turbine blades may be able to be made out of materials (ceramics) that are hard to make with current technology.
loose nut
02-26-2015, 02:35 PM
Jon
Where they quoting new technology or a new type of materials that could be used with this tech. to make engine parts in a way that hasn't been done before.
Jon Heron
02-26-2015, 04:12 PM
It seems to be promoting the 3d printer technology as the breakthrough, I see no mention of a new material?
The breakthrough opens the door for engineers to make and test parts in days instead of months.
"[In the past you had to] melt, mould, carve and turn to get the final product," said Professor Ian Smith, Monash University's vice-provost for research.
"This way we can very quickly get a final product, so the advantages of this technology are, firstly, for rapid prototyping and making a large number of prototypes quickly.
This technology has a very long way to go before they can start to spit out production aircraft parts, but for prototyping 3d printing has been the breakthrough technology for, it must be 10 years by now, no?
Jon
Jon Heron
02-26-2015, 04:34 PM
Speaking of 3d printing, check out this innovation!
http://3dprint.com/47065/argentinian-3d-metal-printer/
Jon
oldtiffie
02-26-2015, 06:16 PM
I wonder if the reception the item got in the USA had a fair bit of negativity in it.
Would it have got a better reception if the process report was made in the USA instead of "off-shore"?
Sour grapes?
https://www.google.com.au/?gws_rd=ssl#q=sour+grapes
