View Full Version : Motor rebuild question.
Pinresto
03-02-2015, 07:27 AM
Hi,
I'm rebuilding the motor that was on my SB9. I'm not sure if its an original or not honestly. It's an old hoover motor. It seems to be in good shape. I've got the motor apart, cleaned and I started painting. The only thing I'm not familiar with is the bearings they are sleeve bearings. Its a brass ring with grooves cut into it. It's backed by a steel ring and the groove has wool wick running through it. The brass ring seems to be in good shape but the wool is shot. I have one brass ring out but not the steel ring. Does it just press out? Does it matter if I press from the inside or out? I need to replace the wool but this steel ring needs to come out first I believe. Is this correct? I can't post pics for some reason but this is the motor info.
Hoover
Sleeve Bearing
AC motor
Frame:kpra
Hp:1/2
V: 115/230
Rpm: 1725
S.f.: 1.25
No. 7674kt03173
Is there a way to date this? I'd like to find some literature or a parts breakdown on this motor. Inside the top bell housing is a stap of 1895. Not sure if that's a part number of what. I'd appreciate any help you can give. Thanks
sarge41
03-02-2015, 11:42 AM
Pinresto: Just a brief caution, those "brass" bearings are probably not brass. I would bet a dollar to a donut, they are bronze. Bronze is good bearing material, brass is not. Just in case you need to fab new bearings.
Sarge
RWO
03-02-2015, 01:19 PM
It's possible that your old bearings can be replaced with modern oil impregnated bronze sleeves. They come in a multitude of sizes. Look here: http://www.mcmaster.com/#standard-sleeve-bearings/=w4xh01 If that doesn't work, I would buy some oil impregnated bearing stock and make all new bearings, doing away with the wicks and such: http://www.mcmaster.com/#bronze-round-stock/=w4xkh7
RWO
Pinresto
03-02-2015, 02:25 PM
Thanks sarge41. They're in great shape so I'll reuse them. I figured it all out today. I got them out and the old wick pulled out. I found a good wick replacement at Michael's. Wool roving.
