View Full Version : Lubrication of the Harrison L5A lathe
John Kronfeld
06-11-2004, 05:21 AM
I've got a Harrison L5A lathe and they have a number of oil inserts for oil lubrication.
Now, how do you get 30 weight oil into these fixtures? I've looked in all the machinery catalogues, and all I can find are greese guns. Thanks, John
motorworks
06-11-2004, 06:49 AM
I use a good quality chainsaw grease gun.The type that is used to grease the nose of the bar.Works great.Just fill it with the oil you are going to use.
e
Ragarsed Raglan
06-11-2004, 10:44 AM
John,
You wanna Wanner!
Best Oil gun ever made - Bar none! Problem is they're best ever price as well.
RR
Alistair Hosie
06-11-2004, 11:18 AM
Hi Martin good to have you back Bud regards. Alistair
Ragarsed Raglan
06-11-2004, 11:30 AM
Hi Alistair,
It's good to be back 'on-line'- nmissed all my machining mates over the last few months.
What's all this about you and green paint then??
RR
nheng
06-11-2004, 12:42 PM
John: for about $7 you can pick up the oil "gun" like Harrison ships with M300 (and probably others). It's about 7" long and develops pressure within a cylinder at the tip when hand pressed against the oil port.
I picked up an identical copy at a nearby Stihl chainsaw and brush cutter dealer. I'm sure others must have it (maybe Euro brands).
Alistair: I'm working on painting a green Harrison M300 and John S. referenced you (and paint) in another thread. If he has already harassed me, I didn't recognize it http://bbs.homeshopmachinist.net//biggrin.gif
Den
