View Full Version : What tooling do these inserts fit?
RichTes
04-11-2015, 10:11 PM
I couldn't find them online. Are they older naming? They must fit something.
http://img.photobucket.com/albums/v15/richtes/inserts_zpsxzltyek0.jpg (http://smg.photobucket.com/user/richtes/media/inserts_zpsxzltyek0.jpg.html)
Thanks,
Rich
lakeside53
04-11-2015, 10:17 PM
A lot of the older inserts like that were for silver soldering onto steel shanks.
Black Forest
04-12-2015, 02:41 AM
I have a very old Walter face mill that uses inserts of that type. No hole and square. They get clamped in place.
PixMan
04-12-2015, 08:21 AM
The flat top, no-hole milling inserts will have an ISO or ANSI standard designation such as SPKN1204 or SEEN43. That box is probably as lakeside53 says, a simple blank used for silver soldering onto a steel shank. I might suggest it could be a wear pad for some mechanism, but the grade CY-7 gives it away as a grade for machining steels. The "style M-168" makes it non-standard and if an indexable insert, would go into a very proprietary holder.
WilsonT
04-12-2015, 08:54 AM
I got 4 similar boxes in a lot at an estate sale about a year ago and have not been able to find out what they fit. I believe that mine have a larger radius on the corners but other than that look the same. I have just resigned myself to making a tool holder for them if I ever use them.
PixMan
04-12-2015, 09:04 AM
They are worth more as scrap carbide than they ever would be worth spending time to make a holder and get questionable performance out of them.
ken226
04-17-2015, 06:02 PM
Thanks,
Rich
they look like SPG434 inserts. I use them in a Shars facing mill:
http://www.ebay.com/itm/new-VALENITE-SPG-434-T00820-Q6-CERAMIC-INSERTS-box-of-10-/251473904396?pt=LH_DefaultDomain_0&hash=item3a8d03430c
http://www.ebay.com/itm/SHARS-2-75-R8-INDEXABLE-FACE-MILL-HOLDER-3-INSERTS-R8-NEW-/350576414872?pt=LH_DefaultDomain_0&hash=item519ffb9098
Rosco-P
04-17-2015, 06:25 PM
Save them for when the price of scrap carbide rises again.
PixMan
04-18-2015, 07:38 AM
If they were SPG434 inserts don't you think they would have been marked as such?
There is no sense of scale in the photo. We don't know if there's a side clearance angle, and if there is, what that angle is. (An SPG would have 11)
I don't understand why people obsess about saving $2 worth of scrap carbide for use in something when you don't need it. Having a little carbide to dispose of is just a matter of collecting it until you have a couple of pounds (or a couple dozen pounds) to unload and turning it in for tools you can actually use.
CCWKen
04-18-2015, 02:54 PM
LOL... I have a couple of 3/8" carbide rods I've been saving for years just waiting for the right time and place to use them. :)
john hobdeclipe
04-25-2015, 10:22 AM
Thanks,
Rich
Could you post the dimensions of these, please?
Sim
04-27-2015, 04:13 AM
They fit some chinese face mills. Like from Sieg.
