View Full Version : Ballistol
GTO Kroh
04-19-2015, 02:15 AM
Anyone using ballistol mixed 20:1 with distilled water in their coolant system? It has so many uses and says about machining applications i was thinking about trying it.
flylo
04-19-2015, 08:00 AM
No but I get mine at Amazon for $9/shipped which is the cheapest I've found. If anyone has a better price let me know, Thanks!
rws
04-19-2015, 08:18 AM
I've seen people using it to clean rifle barrels. It must be another WD40, we've all seen the hundreds of applications for that!
dalee100
04-19-2015, 11:15 AM
Hi,
Ballistol has been around for a bit over 100 years. Originally developed for the German Army at the turn of the last century, it was meant to be the answer to a general purpose cleaner, lubricant for fireams, and even topical antibacterial for minor wounds.
I've not used it as a cutting fluid, but I might be reluctant to cut it with more water, as it is mostly water already. It should provide cooling and at least some lubrication during machining. It would be worth a try in a pinch at least. I would think it's a bit expensive to use though.
Dalee
