View Full Version : Any reason I can't remove the index disc on the bottom of this chuck?
RichTes
04-22-2015, 04:47 PM
It's a 6 1/2" Bison that was on a lathe I bought. Was going to take apart and clean since who knows when last done.
Already removed the index pin mechanism from the lathe since it blocked putting another larger chuck I bought on.
http://img.photobucket.com/albums/v15/richtes/chuck_zps1trhrfpk.jpg (http://smg.photobucket.com/user/richtes/media/chuck_zps1trhrfpk.jpg.html)
Thanks,
Rich
JoeLee
04-22-2015, 04:49 PM
Either there are some hidden bolts somewhere or it's a tight fit with some possible corrosion or dried up oil / coolant that is making separation difficult.
JL.............
otherworlds
04-22-2015, 04:59 PM
Did you loosen all the "set-tru" screws? They're the socket head screws around the periphery of the chuck body. NOT the scroll (square socket) but the hex socket ones.
Spin Doctor
04-22-2015, 07:13 PM
If I send you my address you can ship it to me and I'm sure I can figure it out :rolleyes: There aren't any screws coming from the back side? Either that or remove one of the SHCS's on the front face of the chuck to see if hey pass all the way hrough to the index plate.
RichTes
04-22-2015, 08:21 PM
Thanks. Probably just stuck. I'd have left it on but don't see a reason to have the chuck hanging further out if this isn't necessary (it looks like an addition and not part of the original chuck).
Rich
