View Full Version : Kennametal Kenloc face mill parts?
07-06-2015, 02:02 PM
I've got an old Kenloc KLSR-4 face mill that needs new clamp screws.Only problem is I don't have the KM part# and they are an odd size #12-28 differential screw(setscrew with left hand threads on one end and right hand on the other with an allen socket)
The screws I have work,but in one the hex is nearly stripped and a couple others are getting loose.
I would replace the face mill,but it uses CNMG inserts and eats high manganese steel like it's not there so I want to keep it,plus I have lathe holders that use the other four insert corners so it's a real cost saver too.
If anyone happens to have an old Kennametal catalog from the late 70's early 80's and can look up the part number for me I would appreciate it,or if you happen to have some I will be more than happy to buy them off you.
