I am just getting started with machine tools. I have lots of experience welding but not much work on anything other than a drill press. But at 62, there is no time like now. I found this 1975 Atlas 12 x 36 lathe on Craigslist. It comes with a three and four jaw chuck and some tooling. Very clean and one owner. I am primarily going to be making parts for an old Corvette that I am customizing. Currently asking $2750 but I am unsure of a reasonable price. I would rather pay more and get the right lathe if this Atlas is not appropriate. I do have a local retired machinist that is going to teach me the basics, but he didn't have an opinion as to what it is worth. Any feedback about the suitability of this lathe or price is appreciated! Thanks for your time and consideration.
Yet another Atlas lathe question
My short answer with the information given would be you would probably be ahead of the game to just get a Grizzly, Enco, Precision Matthews or other brand new Chinese import for the same money or a little more. I would do some shopping first on this deal.Kansas City area
Much as I dislike giving money to the chinese, you can get, for that $$, a LOT heavier machine from them.
The atlas is usable, but is a very lightweight, flexible, bouncy machine. A hobby machine, and not suited to heavier work. Just look at the slim and slender bed of that Atlas, and then look at some of the chinese units. A thick heavy bed is good.CNC machines only go through the motions.
Thats a nice looking lathe, ---but, its way overpriced. As mentioned, that kind of money is getting into some of the nicer Chinese machines which would be much, much better...
Now if that was a South Bend in their heavy 10 in about that year range and that clean --- well, then it might be a better price!Last edited by Bill Pace; 07-13-2015, 02:35 PM.If everything seems to be going well, you have obviously overlooked something........
I bought the same lathe recently (mine is the table version with the motor behind). As the others have said it is not as rigid as many other in that size (on an interrupted cut you can visually see the compound jumping). That said if you keep your cuts on the light side you should be satisfied with it. Price wise $2750 seem high to me, I paid $700 for mine (in NE Pa) which had 40 years of grime, but it was complete with no broken parts and little wear. i am very happy with it, but if I had $2700 - $3000 to play with I would have bought a new Import.
Stu
Bought the same lathe several years ago for $600. Was not nearly clean-looking as this unit, but everything worked, came with 3 jaw, 4 jaw & steady rest.
Essentially it's a light duty machine & the spindle thru-hole is fairly small, spprox. 3/4".
My PERSONAL opinion, WAG, eyeball & thumbnail guess of worth is less than half of the asking price. As others said, you can get a lot more machine for that amount of money
I just bought the exact lathe fully tooled in mint/maybe unused shape for $1000 which was a deal. I'd buy it over chines as this is the best Atlas they made with the under moter, dual drive belts, 1/2" bed, 3/4" lead screw, etc. I think $1500 would be tops of it has the follow & steady rest. Atlas is still in business & like buying a john deere you'll always have parts available. People dis the zymak gears but who has ever broke one? Most chinese lathes you have to fix/improve/adjust/tinker with before you use it & after 60 or 70 years you have to replace a zymak part on an Atlas. Try to find the chinese mfg in 70 years. I'd buy this one if you can get the price right. If your close to me send a PM as your welcome to come over & try it. I read in 1970 these sold for $1600 which was alot IMHO. On a side note I just sold a 1934 10" Atlas & she was still going strong.
I have an old ragged-out Atlas. I resurrected it. I like using it. But is it not a production lathe at all. Unless the lathe you pictured comes with a TON of tooling, it is overpriced by a factor of 3. It's clean as a whistle, to be sure.
I'd be investigating a far more capable lathe from Grizzley or Precision Mathews.
The stats looks good, I have not used one. http://www.machinetoolonline.com/PM-1127-VF.html
Dude, I had an Atlas 10".
It was krapy.
I learn a lot, and something I learned
is that even a SouthBend is TWICE as good
as an Atlas. Yes I loved the Atlas, but just
being honest. Let someone else get frustrated
with chatter and unwanted taper.
-DoozerDZER
I've been using a clapped out Craftsman (Atlas) 12x36 for about ten years. The ways are worn, 3/4 turn of backlash in the cross and compound, yet I'm still able to make very accurate parts. These are good lathes for a home shop, never intended for production. That looks like a nice one and if everything is perfect with tooling mentioned, I think it would be worth $1200. Any wear on the ways or other parts brings it to $600- $1000 depending on how bad.
I recently sold a 98% SB 9C lathe with tooling and collet closer for $1200. The ways were barely scuffed. Maybe I let it go too cheap but the 9" is a better lathe than the Atlas in equal condition.
That lathe is the later Atlas 12" machine, the improved version of the 10" Atlas and 12" Craftsman lathes. It has a heavier bed and other upgrades and is a much better machine than the earlier lathes.
They are decent HSM lathes, but that one is overpriced by at least $1000. The rather shoddy repaint also raises questions and a pass is the best advice.Jim H.
Originally posted by biglouie View PostI do have a local retired machinist that is going to teach me the basics, but he didn't have an opinion as to what it is worth. Any feedback about the suitability of this lathe or price is appreciated! Thanks for your time and consideration.
Lathe prices seem to vary widely by where you are. Since I don't know where you are I wouldn't venture an opinion on local prices. That said, I'm pretty sure that wouldn't bring $2,750 on Craigslist around here.
Charles
