View Full Version : Another home brew EDM
G.A. Ewen
06-22-2004, 08:17 AM
Found this on another site......................
http://pico-systems.com/edm.html
[This message has been edited by G.A. Ewen (edited 06-22-2004).]
ibewgypsie
06-22-2004, 07:08 PM
Electrostatic discharge machining?
I have a book to build a edm with a vibrating pen engraver..
Not really a edm either. Both will work to remove taps or other boo-boos thou.
David
ibewgypsie
06-22-2004, 09:33 PM
Actually, do the research for me, I have a old drill press there next to my welder.. do I just need the solution and rod? Should I make a dedicated machine? I really don't wanna use the cnc.. I think the vibrating pen ideal works pretty well to stutter the arc to the electrode, instead of rotating it like this guy does.. imagine needing a brush connection on the electrode.. two sets of arcs..
I hate broken taps. Stinking metal in the tap is so hard.. So hard to get out.. I relish in the ALum-and using my anodizing etchant tanks to remove from aluminum, they rot right out.
Even if it ain't a real edm.. it'd be neat to have right there and handy..
I was thinking they pulse to a HV capacitor and discharge through a motor driven rotary switch. Really works the capacitor, charging and discharging rapidly. I was thinking pretty substantial voltages on a real edm.. actually vaporizing the metal.. and a wire feed.. Like a mig..
David
[This message has been edited by ibewgypsie (edited 06-22-2004).]
