Weston Bye
08-16-2001, 11:46 PM
nheng
Check out my article in the Sept/Oct 2004 HSM, "Machining a Spiral Cam".
Lacking a tool post grinder, I made do with a wheel mounted on a sewing machine motor. I borrowed the compound slide from my Atlas lathe and mounted the cam to be ground, on the shaft of a stepper motor. The grinding wheel turned at right angles to the cam so as not to overcome the holding torque of the stepper motor. The spiral cam produced 0.1mm increase/decrease in diameter for each step of the stepper motor. A 100 step/rev motor would provide a lift of 10mm to the cam follower.
Since the article, I did the same operation with a Sherline mill by rotating the spindle head 90° with a grinding wheel mounted on an arbor and held in the spindle, and holding the stepper motor with the shaft vertical in the milling vise. All the usual steps were taken to protect the ways and leadscrews from dust and grit.
Weston Bye
Grand Blanc, MI
Weston Bye
Grand Blanc, MI
