View Full Version : Angle cutter with threads to mount? First one I ever saw.....
09-27-2015, 06:26 PM
Picked this cutter up for pennies a while back, finally got it unstuck so I could modify the shank. I had never seen one with apparently factory internal threads.
I assume this is due to the small diameter. It is about 40mm OD.
http://img.photobucket.com/albums/0803/jstanley/tooling/cutter%20with%20threads_zpsqnlqpgok.jpg (http://smg.photobucket.com/user/jstanley/media/tooling/cutter%20with%20threads_zpsqnlqpgok.jpg.html)
09-27-2015, 06:33 PM
Got a few of those,still available,but pricey-
https://www.fdtool.com/images/Pdf/fdcatalog%2026.pdf
Don't think size is the issue since dovetail cutters can be had much smaller.Maybe it's a hold over from a time before integral shank dovetail cutters?
JCHannum
09-27-2015, 06:44 PM
Brown&Sharpe list 60* cutters with threaded bores and threaded arbors for same in their 1935 Catalog. Available if 3/8-24 and 1/2-20 left hand threads.
This makes sense as it is a dovetail cutter and cannot have interference on the flat face.
09-27-2015, 10:02 PM
Much smaller and it would be integral shank.
And this one is RH threads, but they are correct to be tightened by cutting force. And tight they were.
jhe.1973
09-28-2015, 01:47 AM
Inherited two of these in the original boxes from my dad.
It's been eons since I saw boxes like these with the metal tabs that you bend over to keep the lids on, Thought they are cool:
http://i1096.photobucket.com/albums/g327/jhe-1973/Dovetail%20cutters_zpswofvqhik.jpg
:cool:
Zahnrad Kopf
09-28-2015, 10:14 AM
The ones I have are branded B&S. Came in a tool box from an old mentor and likely from the 50's judging by the boxes. ( metal reinforced/staple type corners too )
