I'm curious why i'm coming up with this crazy number when i use the feed per tooth X number of teeth X rpm equation to figure out feed.
for instance i was running a horizontal mill, with a 3.5 inch face mill. not sure on the number of teeth, but i think it was 6, at about 1200 rpm (top speed) and a feed of 22in per minute. Now i was looking through a machining book and it said the feed per tooth for aluminum with carbide inserts has a feed rate of .020in per tooth. So if i put that into the equation of .020X6X1200 it comes out as 144 inches per minute! now i know that that is wayyyy too fast (i don't even think the rapid on the machine goes that fast).
So now i'm curious... if i were to have put in a stainless steel block, and having not milled any stainless in my short career thus far, i would HAVE to start with the suggested feed/spindle rates in teh book and tweak from there... BUT what if the feed rate was that far off (proportionatlely) like it is when i try to figure out the 'textbook' speeds for aluminum? I know for a fact if i tried to run at 144 ipm at a decent doc, there would be hell to pay :P. BUT if someone had never milled aluminum before and tried that equation... they would have started off there. So i'm curious if the same problem will occur for me (proportionately) when i try to figure out speeds/feeds for other metals? Or is aluminum just suggested at insanely high speeds/feeds and the rest are alright?
[This message has been edited by Derek13 (edited 06-07-2004).]
