View Full Version : Bridgeport Mill dial division increments
Smokedaddy
11-07-2015, 12:18 AM
I should know this but I don't. <red-faced> If I had to move my Bridgeport Series 1 mills table in the X direction 100 microns how many clicks would that be on the dial, approximately 3?
Regards,
-SD:
PStechPaul
11-07-2015, 12:30 AM
I had to look it up to be sure, but a micron is about 39.3 micro-inches, so 100 microns is about 4 mils, which should be four divisions on a Bridgeport and most other non-metric machines.
Smokedaddy
11-07-2015, 12:45 AM
Thanks very much!
Forrest Addy
11-07-2015, 01:59 AM
0.000246 Biblical cubits. Pharonic slightly less, Assyrian slightly mere but NIST standards are sadly lacking when it comes to ancient measures. Depends on how old your Bridgeport is.
Jim Williams
11-07-2015, 08:03 AM
25.4 microns = 0.001 inch. Four marks on the Bridgeport will be a tiny bit over 100 microns. I used to have to think in microns in relating to hole sizes in cellulose acetate spinnerets.
Jim
