I have just about completed another project that's been on the bench, one of my benches... for almost five years.
This is a flasher circuit and solar cells.
The machining part.............
I made the tilt / swivel / clamp mount out of stainless for the solar cells and also the PVC enclosure for the photo eye and the mount for it.
This is going to clamp to a 1" square tube arm.
The circuit consists of a small 6 volt flasher unit with a photo eye that came out of one of those barricade flashers.
I removed the photo eye and mounted it externally in the PVC enclosure that I made. The circuit board and associated parts are enclosed in the weather proof electrical box.
Here is what I want to do.
I want to bring in all the connections into the box, connect them to the terminal strip and then back out to what they have to connect to.
What I want are some ideas on how to make the actual physical connections inside the box. I've included a sketch of what has to go into and come out of the box. The photo eye part is done, that was simple. What is left is the battery has to connect to the terminal strip, it should be fused and so should the light, there is a two fuse holder mounted in the box, I'm just not sure where in line to put it.
I also have an on/off switch that needs to be placed in the circuit also. The light is in series with the negative terminal of the battery.
The switch has to cut power to the light but not interrupt the charge to the battery. The sketch is in the next post.
JL..................
