View Full Version : Identify Albrech chuck
steverice
01-05-2016, 05:52 PM
I need to get some new jaws (nomenclature) for my keyless Albrecht chuck, minimum 1/32 max 1/2", looking at the parts available there are a couple different model the same size range, how do identify which chuck I have?
Thanks in advance.
MyrtleLake
01-05-2016, 09:23 PM
All the "130" models chucks (1-13mm, 1/2" capacity) use the same jaw set regardless of the particular mounting model of the chuck (JT33, integral shank, etc.). There will be a choice, though, of the very expensive diamond coated jaws and standard. Unless your Albrecht has a gold colored knurl on the sleeve, get the standard jaw set (part #70712).
steverice
01-06-2016, 11:17 AM
Thanks for your help!
