View Full Version : starrett oil harding steel how to mill
Brett Hurt
01-06-2016, 09:27 PM
does it machine just like other steel I have never machine it what should I look for ie speed for 1/2 in. thanks
dalee100
01-06-2016, 09:51 PM
Hi,
Yep, it will machine well. I use cutting speed of 80fps to 90fps depending on the size and power of the machine I'm running.
Dalee
Richard P Wilson
01-07-2016, 04:25 AM
Hi,
Dalee
Is that right? fps? Not fpm?
lynnl
01-07-2016, 07:59 AM
Yeah, that mistake seems to be gaining in popularity here. I've noticed it several times recently.
That's the problem with writing laxity, bad grammar, poor spelling, etc., mistakes multiply like rabbits.
.... or maybe fps was intended but the quantity was off by a factor of 60.
01-07-2016, 08:30 AM
Use carbide mills and it's all good;):cool:
Doozer
01-07-2016, 12:00 PM
It's high speed machining, brough.
You cut it so fast, the chips don't even
land on the machine table. That is how
to roll.
--Doozer
kevinvallelunga
01-10-2016, 09:33 PM
I think he meant 80-90 SFM, SFM meaning surface feet per minute. With hss tooling that would be about right.
RPM=SFM*3.82/cutter dia
611.2=80*3.82/.50. Might be a little too fast on a manual mill.
Sent from my SM-P900 using Tapatalk
