View Full Version : O.T. what is this ?
steve herman
01-13-2016, 11:39 PM
Found this at the range, the primer reads 38 short colt.
all aluminum.
http://i784.photobucket.com/albums/yy126/steveherman/002_4.jpg (http://s784.photobucket.com/user/steveherman/media/002_4.jpg.html)
http://i784.photobucket.com/albums/yy126/steveherman/001_3.jpg (http://s784.photobucket.com/user/steveherman/media/001_3.jpg.html)
http://i784.photobucket.com/albums/yy126/steveherman/004_2.jpg (http://s784.photobucket.com/user/steveherman/media/004_2.jpg.html)
JoeLee
01-14-2016, 12:01 AM
Someones home made snap cap, flare gun cartridge or grenade launcher shell.
JL.............
flylo
01-14-2016, 12:22 AM
Yoy can turn it down to use in a 12, 20 or 16 ga but it won't be very accurate.
Richard King
01-14-2016, 12:34 AM
Send the pic to this guy. http://www.oldammo.com/contact.htm
Doc Nickel
01-14-2016, 01:20 AM
That probably goes to a 37mm or 40mm "grenade" launcher. If it's 40mm, it's probably something the local PD or state police practiced with and left behind. If it's 37mm, it probably fits one of the civillian-legal lookalike "flare launchers".
In either case, it's either just a blank, a riot-control round (fires a beanbag or a cluster of rubber balls) a flare, or something similar.
Let us know if you find out for sure.
Doc.
steve herman
01-14-2016, 02:27 AM
Doc.
I'ts 40mm dia. a lot of PD and state police use this range
dp
01-14-2016, 03:24 AM
It isn't what it appears to be. It is a center fire primer installed in a Colt .38 short brass shell which is inserted into an aluminum carrier the purpose of which is not obvious. Might be a blasting initiator. The threaded hole in the side suggests something is screwed into it and that something could be det cord, for example.
winchman
01-14-2016, 04:49 AM
How about a picture of the other end to show what's inside?
Toolguy
01-14-2016, 10:11 AM
The 38 Short Colt was probably a blank to propel whatever was in the blue casing.
steve herman
01-14-2016, 01:59 PM
http://i784.photobucket.com/albums/yy126/steveherman/005_3.jpg (http://s784.photobucket.com/user/steveherman/media/005_3.jpg.html)
http://i784.photobucket.com/albums/yy126/steveherman/001_4.jpg (http://s784.photobucket.com/user/steveherman/media/001_4.jpg.html)
