Hi Everyone,
I am finishing some carbide burnishing wheels for a Swiss pivot burnishing machine. The company has been out of business for a few decades so I can't call them! I have a couple of blueprints from 1954 that are helping me, but there seems to be a slight variation between machine spindle sizes.
The 10mm bores are what is critical and I am not too sure as to how to translate/interpret the bore tolerance. Both wheels should fit the same on the spindle stub, but each print is written in a different way for the respective wheel.
Here are the areas in question from the two prints:
Is anyone able to tell me what the bore tolerance is in inch dimensions? Probably just a few tenths, but I would like to know for sure.
Also, in the top view, Google Translator comes up with:
"Unscrew hole after Meul outer diameter" for "Loch nach Meul Aussendurchmesser"
ausdrehen
and "Ecke erst bei Montage ausdrehen" becomes "Corner until assembly unscrew"
Just doesn't sound quite right!
Thanks for any help that anyone can provide!
ausdrehen
