I came to ask a question and found a similar one already being discussed but my question is not how long can a carbide end mill last but what would be the safest practical speed for a small cutter? Would running slower than optimum recommended speeds shown by the calculators be better or worse?
The particulars are, 1/8" good quality carbide 2 flute end mill being used on 4140 of approximately RC32. Time to do the job is of no concern, I don't care how long it takes within reason, but avoiding the dreaded chatter and resulting chips is a concern! Should I cut dry with air to blow away chips or use coolant? I have searched feed/speed calculators and find best rates for production, etc but I simply need to cut this one slot without chipping/breaking my end mill regardless of how long it takes to do it.
