How do you adjust aka set an adjustable reamer with an odd number of blades? How do you measure it?
adjustable reamers
Lakeside got it. My suggestion would be to do a test hole on scap . If you get that right you can do the good piece. The downside is that the drilled hole will have to be very close to the final desired diameter.
RandyDo yourself a favor and see if your TV carrier has America One News Network (AONN). 208 on Uverse. It is good old fashion news, unlike the networks, with no hype, bias or other BS.
Agreed, with this addition.
Lets say you are reaming wrist pin holes in 4 connecting rods. You take the first one and with 3 or 4 iterations of adjusting the reamer, you cautiously sneak up on that perfect double grunt push fit of the pin in the small hole.
With your now perfectly adjusted reamer you proceed to ream the remaining 3 rods, and the pin falls through them all just with gravity.
What?? (Well, ok, maybe I cleaned that up a bit. )
It may or may not be obvious, (it wasn't to me the first time or three!!) the reamer cuts differently depending on how much material it/you are removing. When sneaking up on that perfect adjustment, do one hole to confirm either correct adjustment or that the hole is still undersize, then do all the holes before making the next adjustment.
This way you will be removing the same amount of material each time and results will be much more consistent.
DaveLast edited by becksmachine; 04-09-2016, 12:33 AM.
This!!!!! Having spent years setting such adjustable reamers for production use, consistent tool loading is critical for consistent results.
DaleeIf you think you understand what is going on, you haven't been paying attention.
