View Full Version : Air /hyd jack on a press?
fastfire
04-19-2016, 11:13 AM
Can it be done? Looking to make air/hyd on my bottle jack and will need description of how to do this.
Any helpers here?
04-19-2016, 12:06 PM
Are you just wanting to use and air/hyd jack on your press?Or are you wanting to build an air/hyd jack?
fastfire
04-19-2016, 12:45 PM
Build, I have the time.
flylo
04-19-2016, 01:06 PM
I put on on a 30 ton press & it worked great.
Illinoyance
04-19-2016, 01:39 PM
HF is selling air operated jacks so cheaply that it is hardly worth building one.
Toolguy
04-19-2016, 01:52 PM
I put an HF one on my 20 ton hyd. press and it works fine. It is a bit slow compared to a hydraulic pump with electric motor, but gets the job done.
CCWKen
04-19-2016, 01:57 PM
Yeah, build your air powered hydraulic pump first then we'll talk. :)
I bought a 20ton a few years ago when they were $89 plus I had a coupon to boot. You can't build one for that. The 12ton is now $89 but HF puts them on sale often.
Here's the 20ton: http://www.harborfreight.com/20-ton-air-over-hydraulic-jack-95553.html
Here's the 12ton: http://www.harborfreight.com/12-ton-airhydraulic-bottle-jack-61382.html
dave_r
04-19-2016, 02:14 PM
You are banned from posting to this site for one month.
04-19-2016, 04:20 PM
Ya,this site is all about a hobby that involves spending $100 to build a $.25 part :D
boslab
04-19-2016, 06:09 PM
How the hell did you know it cost me $100 for a lathe to make a 25c doorknob, you've got my shop bugged, please don't tell SWMBO, or she'll expect $95.75 change!
Mark
flylo
04-19-2016, 06:28 PM
Not counting labor. They are talking min wage at $15/Hr & we make 15 cents when you ciunt buying, moving, wiring, tooling, etc.:rolleyes:
Rosco-P
04-19-2016, 06:40 PM
+1 for applying common sense.
vpt
04-19-2016, 08:54 PM
I picked up a enerpac air/hydro pump from the local salvage yard for $25. I plan to use it on my HF press.
Boostinjdm
04-19-2016, 09:31 PM
I broke two air/hydraulic jacks. Went with a fast lift 20 ton jack and was happy till I got my big press done.
GEP
04-19-2016, 10:00 PM
What is ciunt ? Oh forgot the spell checker stopped working
04-19-2016, 10:09 PM
Back on topic,a few weeks back I bought one of these air over pumps from HF-
http://www.harborfreight.com/automotive-motorcycle/hydraulics/10000-psi-air-hydraulic-pump-98318.html
And then you can get off fleabay one of these which can be packed around and used for a variety of other tasks-
http://www.ebay.com/itm/20-tons-4-stroke-Single-Acting-Hydraulic-Cylinder-Lifting-Jack-Ram-YG-20100-/221956694102?hash=item33ada66056:g:RG0AAOSwBLlVNuL m
fastfire
04-20-2016, 12:33 AM
Wow, that HF is cheap, I may have to BUY this one.
Hopefuldave
04-20-2016, 05:29 PM
When you did, did you invert the jack to get it ram-downwards? If so, what needs modding, on a manual jack the pump pickup often needs extending to keep it from sucking air, is it similar with the air-over jacks?
Thanks,
Dave H. (the other one)
