5-axis laser demo
  • cuemaker
    • Nov 2004
    • 1913
    5-axis laser demo
    Weitere Informationen: https://www.trumpf.com/de_INT/produkte/maschinen-systeme/3d-laserschneidanlagen/3-D-Laserschneiden einer Gurtkonsole mit der TruLaser ...
    I want one...dont know if I can use it..but I want one
  • Dan Dubeau
    • Dec 2008
    • 4383
    #2
    Originally posted by cuemaker View Post
    https://www.youtube.com/watch?v=ewjIVIUri1s
    Cool. Let us know when you get one ok? I'll send you some work.
    • George Seal
      • Oct 2002
      • 325
      #3
      better still you buy it and I will use it
      George from Conyers Ga.
      Remember
      The early bird gets the worm, BUT it's the second mouse that gets the cheese.
      • wierdscience
        • Jan 2003
        • 22088
        #4
        Something tells me if you could afford that,then you could probably also afford the people to run it
        • garyhlucas
          • Mar 2013
          • 2407
          #5
          I wonder if this is a fiber laser? The new fiber lasers do the lasing in a doped optical fiber and use diodes to pump them. It is visible light in the blue spectrum I believe. About 80% efficiency and they have already built ones with 150kw of continuous beam power! This is likely to bring the cost of low end laser cutters way down in the near future, maybe to the DIY level and metal cutting.
