Something I learned long ago came back around again,so I thought it would be a good discussion.
In the smaller sizes drill bit quality can vary wildly even in the same batch of drills.This job came in at work to drill 460 -1/16" diameter holes in 1/4" thick 304 Stainless.My go to drill for drilling stainless is a good quality cobalt split point.So I ordered up a few drills and having been down this road before I ordered 3 dozen.
So I got my material and I got my drills,ran the numbers and 20-40 fpm was recommended in the mfg's literature with cutting oil for lube.I tested out a few holes on some drop material and found 1450 rpm to be the ticket,or a little less than 25 fpm.Feed rate,well this is 304,so it's whatever the drill would take with no screwing around(dwelling).Set the job up in the B-port and just for fun decided to record how many holes each bit would produce.
Bit #
1- 9
2- 7
3- 14
4- 5
5- 19
6- 11
7- 15
8- 21
9- 3
10- 11
11- 31
12- 16
13- 28
14- 38
15- 17
16- 22
17- 36
18- 41
19- 0
20- 11
21- 18
22- 21
23- 27
24- 15
25- 11
26- 13+
In the picture is #19 right next to #26.Notice the s-bend,that drill is soft as butter and didn't even mark the surface
Bit #
1- 9
2- 7
3- 14
4- 5
5- 19
6- 11
7- 15
8- 21
9- 3
10- 11
11- 31
12- 16
13- 28
14- 38
15- 17
16- 22
17- 36
18- 41
19- 0
20- 11
21- 18
22- 21
23- 27
24- 15
25- 11
26- 13+
