The secret, after myself having done many castings Dental castings, Using the lost wax method of course but even here without the lost wax the secret is in the preparation( and not pouring with bare feet) sorry couldn't resist that. Just plain madness really .
If you get the mould carefully made taking a bit more time, so as to remove a lot of the excess metal being cast, which will eventually need to be removed after casting, which makes little sense to me sorry. Get the initial mould as near as perfect *IF YOU CAN* ,of course to the end shape required. And save yourself a lot of unnecessary metal removal. Otherwise good idea to use scrap aluminium. .Now where did that patient run off to the one with the aluminium teeth. LOL Alistair
In WWII, Lucien Yeomans patented an idea for cheap lathes made from concrete, pre-fab metal and jigs to place the parts. Now the design is open source.
I am impressed he got as much of it going as well as he did. Being prepared to design then weld all those bits together to make gearboxes etc etc was impressive. Some of us with better kit to do the works with should be humbled.
I'm not exactly sure what he accomplished by casting a ring and then turning it to a geometric shape. I would have been impressed if he casted something to an actual unique shape.
I think he simply obtained a piece of stock from which he could machine the part he wanted, that's a big lump of plate or bar if you're somewhere without much money or a local metals stockist ;-)
- Nick
If you benefit from the Dunning-Kruger Effect you may not even know it ;-)
My hat's off to the guy. As a machine tool it has obvious deficiencies but as a scratch built machine tool built on the cheap with limited resources it's quite an accomplishment. Machinists 150 years ago built the working parts of the Industrial Revolution using machine tools not much better.
While this home built machine tool may not compete in productivity with a factory built machine I'm quite sure a capable fellow working with care can make any part within its work envelope that does nor require turned screw threads, and, truly cylindrical or flat features may be a real challenge for its axis geometry.
An unthinking person may belittle this endeavor and make disparaging comparisons but the fact remains: it is a lathe/milling machine with limited utility built by an individual of no small talent and remarkable determination. I'm sure none of the scoffers and sneerers have ever scratch-built anything 1/10 the complexity and utillity of the targer of their scorn and worked it through to completion: sour grapes redeux
