What material could I use to line a band brake that is used for parking only? The band is around one foot in diameter when mounted. It is 28mm wide. This is for a small tractor.
Material for band brake
How big is your waist?
A 12" diameter gives a circumference close to 38". By the time some of us removed the
buckle at one end and the notched portion at the other end of a man's leather waist belt,
we'd have something suitable in hand for that application of yours.
we'd have something suitable in hand for that application of yours.Play Brutal Nature, Black Moons free to play highly realistic voxel sandbox game.
I did that about 15 years ago on a small hydrostatic drive tractor where the brake band served only as a parking brake, over the years it has actually served as a stopping brake many times but then from the size of the brake he describes I am sure his tractor is a heck of a lot heavier than mine. Although it might sound like a backwards thing to do when the leather glazed over and was dried out I wiped it in a light oil and diesel mixture to soften it and the darn thing holds better than it did dry!
Ford Model Ts used wood or woven cotton bands in the transmission. (Primary brake drum inside.) The parking brake was metal-to-metal on the rear axle brake drums. Modern replacements now include Kevlar for the transmission bands and friction brake lining for the rear drums. Since it's a parking brake, just about any material could be used. You didn't mention if the lining was riveted or glued to the band.
Leather works well if it is subject to being contaminated with oil or grease. I tried commercial brake liner on a Beaudry power hammer brake and it would slip once any lube got on it. I replaced it with a piece of saddle leather and that solved the problem quite handily since leather will grip even when wet.
Leather is the easiest for me. I have whole sides of Herman Oak leather and all the tools to work it.
Now what steel should I use for the actual bands? One side has only the two ends of the band and the other the band is rusted in half.Location: The Black Forest in Germany
Signode is a significant producer.
Comes in a variety of widths and thicknesses. You'll want to visit the
loading dock areas of companies that ship objects on pallets secured
with banding strap and ask nicely for some lengths.
If you get it fresh, there is often perfectly good used strapping being
tossed into the scrap bins at sites that receive objects on pallets.
That's the stuff, very handy stuff, I always keep some for odd brackets, exhaust straps, even repaired a band brake on a 1000 ton gantry that was stuck on a ladle cooking the ropes, I did not fancy a rope change, not 108 falls of 2" cable at 2 in the morning
It's hard to drill but a Whitney punch goes through nice, I used solid rivets, snap and set too, never thought learning that would be handy
Mark
USA Maryland 21030
