View Full Version : Swivel heads for shop made machinist jacks?
challenger
01-17-2017, 01:39 PM
Where can I purchase these? I am making a few jacks and can't find these?
Thankshttps://uploads.tapatalk-cdn.com/20170117/94590a7519a852f846dcdc9b8f24c7fc.jpg
Galaxy S4, Slimkat
If I wasn't married I'd quit fishing :)
softtail
01-17-2017, 01:59 PM
McMastercarr and search "Vibration-Damping Swivel Leveling Mounts". May be other alternatives on their site as well under fixturing/workholding.
Toolguy
01-17-2017, 02:28 PM
Carr-Lane tooling components. www.carrlane.net
reggie_obe
01-17-2017, 02:34 PM
Or Jergens: http://www.jergensinc.com/
PStechPaul
01-17-2017, 03:24 PM
Make one from a ball joint?
http://www.banggood.com/M10-Spare-Parts-Joint-Ball-For-50CC-70CC-90CC-110CC-125CC-ATV-Quad-Bike-p-1117993.html?rmmds=search ($4)
http://img3.banggood.com/thumb/gallery/oaupload/banggood/images/96/B0/36dee5f1-7d98-45bd-9d3b-fb0448858f32.JPG
or, as suggested:
https://www.mcmaster.com/#swivel-leveling-mounts/=15ydepj
https://www.mcmaster.com/#swivel-leveling-mounts/=15ydfwp (https://www.mcmaster.com/#swivel-leveling-mounts/=15ydepj)
Mcgyver
01-17-2017, 03:52 PM
not directly answering your question, but they're not hard to make.....ball and socket: a ball bearing silver soldered to the end of the threaded section sits in bored recess forming the socket. A tiny bit of peening locks the socket - because its hard to hold i've done it with vise grips Just squeeze the edge of the cup
Black Forest
01-17-2017, 04:20 PM
Or use a cylinder that the ball end goes in and turn a grove for an O-ring to keep the foot on the ball.
PStechPaul
01-17-2017, 06:18 PM
You could use a ball-end mill to make the socket, insert a steel ball with a threaded hole or shaft, and cut an internal groove to hold it in place with a spring clip.
Mcgyver
01-17-2017, 06:36 PM
I left the bottom of the bore a cone, I don't think it matters that its not round unless a key function is smooth movement. The KISS method.
http://i.imgur.com/sBlBg82.jpg
http://i.imgur.com/MWwjWdM.jpg
Illinoyance
01-17-2017, 07:22 PM
At least one maker of c-clamps makes replacement swivel pads for their clamps. I just can't remember which ones.
Illinoyance
01-17-2017, 07:28 PM
So, I did a search.
https://www.amazon.com/Wilton-C-Clamp-Pads-Flat-Spindle/dp/B002EY3ZVG
randyjaco
01-17-2017, 07:37 PM
They're really not hard to make. The majority of my C-clamps are flea market finds. The ones without the swivels are usually heavily discounted, so I have made over a dozen.
challenger
01-18-2017, 06:49 AM
Thanks folks. I'll try and make my own. If that's fails I'll make a purchase.
Galaxy S4, Slimkat
dian
01-18-2017, 08:45 AM
why not use these (they cost almost nothing, hardened):
https://www.brw.ch/1/BRW-ToolShop/1/Category/700/AMF-Spannschrauben#SelectedPageSize=10&SelectedViewType=List&SelectedSorting=NotSorted&SearchCategoryId=700
360340, 360360, second page
Spin Doctor
01-18-2017, 04:08 PM
The last time I made a set of swivel head jacks I used the pistons from hydraulic piston pumps. Gave them away in 2005 though
BCRider
01-18-2017, 04:16 PM
If time is important I'd just make them. It takes longer to order up something and usually costs way too much for shipping on a small order to justify buying them unless you need a lot.
We're not talking about rocket surgery here either. A simple drill hole leaves a cone shaped seat in the swiveling button and a piece or two of HSS tool bits ground to a "sort of" half ball shape with support pin or quarter round cutters depending on what you have makes short work out of making a close enough ball end on the screw. After all you only need about 15 or 20 if swivel and it is a static seating. So no big deal.
I do like the idea of an inside groove to take either an O ring or a split wire spring ring. Avoids a lot of hammering and risk of going too far and pinching the ball in the socket.
