View Full Version : Photo: Long Lineshaft Lathe
Carl
07-29-2004, 12:09 AM
http://img.photobucket.com/albums/v35/lathefan/36352937.jpg
Mike Graham
07-29-2004, 07:39 AM
Can you even imagine how excrementally boring it would be to run that lathe? No feeds, carbon steel tooling... it would take all day to take a cut, and you'd be turning that handwheel the whole time. Wretched.
Mike Graham
Caledon, ON
http://web.295.ca/mike_graham
[This message has been edited by Mike Graham (edited 07-29-2004).]
Lee
07-29-2004, 08:30 AM
Geez. I imagine it would rust up again before you finished the cut. http://bbs.homeshopmachinist.net//wink.gif
Lee
07-29-2004, 08:38 AM
Then its a good thing that he is just facing the flange, isn't it?
07-29-2004, 08:51 AM
You guys are old and blind http://bbs.homeshopmachinist.net//biggrin.gif He has power on that carriage,notice the pull knobs?
Mike Graham
07-29-2004, 10:20 AM
<font face="Verdana, Arial" size="2">Originally posted by wierdscience:
You guys are old and blind http://bbs.homeshopmachinist.net//biggrin.gif He has power on that carriage,notice the pull knobs?</font>
Unless there is a keyway in the leadscrew that is hidden in behind, I don't see any source of power for a feed. Mind you, they might be able to use the leadscrew itself as a feed for finishing cuts.
Mike Graham
Caledon, ON
Dave Opincarne
07-29-2004, 09:56 PM
If there's no feeds then how does he turn the handwheel from where he's standing?
Oh wait I just figured it out, must have a happy wife. http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif
07-29-2004, 10:48 PM
If I'm not mistaken the handlewheel for the cross feed has been removed. It must be running on power. Compound handle is gone too. Talk about old and blind http://bbs.homeshopmachinist.net//biggrin.gif
Probably took it off so it wouldn't wind up the chips.
[This message has been edited by Evan (edited 07-29-2004).]
speedy
07-31-2004, 08:26 AM
Dave, the turner could have a happy wife but i think that he is left handed and could have been self employed when this shot was taken. There appears to be a steady supporting that big mother while the operater controls the machining operation by telepathy (they had some strong willed men back then before new age men arrived)
07-31-2004, 06:04 PM
I hate to break it to you,but many lathes have a keway milled in the leadscrew,the seperate feed rods didn't come in until after WWII from what I have seen.Plus I like the system,it drives everything from the one shaft,and many times both feeds can be engaged at the same time,like on the Hendey machines from 1920-1950.
beckley23
07-31-2004, 09:44 PM
Separate feed rods have been around since long before WWII. Story goes that some manufactures felt that the slot in the lead screw warped it, an incorporated a feed rod. I've seen and used both systems, couldn't tell any difference.
Take a look at the cross and compound screw ends, they're square for crank handle.
Harry
[This message has been edited by beckley23 (edited 07-31-2004).]
speedy
07-31-2004, 10:32 PM
as in the SB and others aye wierdscience? and Beckley, that is what the operator had in his left hand, his crank.didnt you know.
brunneng
08-01-2004, 12:28 AM
How would you like to have been the guy(s) that had to scrap them ways true? wow, and next year I'll do the other side
08-02-2004, 07:40 AM
Alistair did those with his side grinder http://bbs.homeshopmachinist.net//biggrin.gif
