View Full Version : need a 5/8-12 RH Acme tap
metalmagpie
04-30-2017, 10:13 PM
Making a slide hammer adapter to fit my Proto slide hammer. I need a 5/8-12 RH Acme tap. Nobody seems to carry one.
Ideas?
metalmagpie
10KPete
04-30-2017, 10:15 PM
Never heard of that size. Single point???
Pete
lakeside53
04-30-2017, 10:29 PM
Is it square thread or real acme?
Acme is not normally "single pass" - there a set of taps, or a multi-stage (Tandem) tap for one pass. Even if you find one...$$$$
As a reference, here's an import 5/8-8 for $120. https://www.mscdirect.com/product/details/04794400 USA is $180. OK...halve that 'cos it's MSC.
Single point it.
tom_d
04-30-2017, 11:11 PM
That's definitely an oddball size there. The standard for 5/8 is 8tpi. How did you determine the 12 thread number, and are you sure it's a 5/8? My reason for asking is I'm wondering if by measuring from thread to thread to get the 12, but you have a 6 thread that's a double start? Still an odd one, though.
Is the thread form symmetrical? Reason for asking is that there is such thing as a 5/8-12 in the Buttress thread form.
danlb
04-30-2017, 11:23 PM
Might this be an instance where an Evan-nut would work? A melt in place piece of delrin can take many forms and be used for many things.
Dan
RichR
04-30-2017, 11:34 PM
Googling for:
5/8-12 acme tap
returns a link to:
e-taps.com/ofertapage-20110.html
They only list an ACME 5/8-12 Finisher and it says to email or call.
metalmagpie
04-30-2017, 11:48 PM
Caliper OD = 0.624" ergo 5/8".
Put a 12 tpi thread gage on it and it dropped right in. Doesn't fit, of course, but you can easily tell it isn't 11 or 13.
Seems like Proto and Mac put Acme threads on their slide hammers.
Of course, they could be buttress threads or maybe square but my eyes aren't up to deciding which.
metalmagpie
metalmagpie
04-30-2017, 11:49 PM
Sadly, it's in a blind hole. :-( One of those tandem taps definitely won't work.
I have a good workaround, this is just me wondering.
metalmagpie
MattiJ
05-01-2017, 12:32 AM
16mm 2mm pitch metric trapezoidal tap would be a lot more common but its 12.7 tpi..
metalmagpie
05-01-2017, 02:15 PM
I got out my 10X magnifier head band and really looked at the thread. It isn't acme and it isn't 60 degree based either. It appears to be some proprietary thread with round tops and straight sides. I'm going to punt on this one.
metalmagpie
754
05-01-2017, 02:35 PM
Can you work around blind hole, like make bushing or drill other end open then fill...then single point it.
Sometimes roughing with a 60 deg tool first..eases the real threading.
redgrouse
05-01-2017, 02:44 PM
Hi metal magpie, try these people -- Tracy Tools in the UK http://www.tracytools.com/taps-and-dies/acme-taps
They have them listed in various sizes.
John
danlb
05-01-2017, 03:17 PM
metalmagpie
Ok, time to look at alternate plans? Cool!! ; I'm not sure what you are trying to tap but had some ideas.
First, if you find a tap with a matching thread ( 1/2 - 13) can you use the trick where you dill the hole to the right size, then cut a hardwood shim to pack into two of the flutes to make the effective diameter 5/8? It will then be cutting with only one (or two) edges but that might get you there.
Second, if you have a shaft that is 5/8-12 with an odd thread form, is the part you are threading soft enough to make the shaft "self tapping" by grinding some flutes into the shaft? You can make up for the damage by using locktite when you assemble it.
Just throwing those out there.
Paul Alciatore
05-01-2017, 04:13 PM
Single point it? Are you serious or just kidding? The basic thread height of an acme thread is 1/2P. At 12 TPI the pitch is 1/12 = 0.0833"/2. Actually you need to cut a bit deeper than that for clearance. Since the thread is on both sides of the hole you multiply that by 2 and get a total thread height of 0.0833". Now, 5/8" = 0.625". And 0.625" - 0.0833" = 0.5417". That's about your minor diameter. So, you are going to grind a tool with a total width, shank plus the cutting tip's protrusion, is less than that figure. I calculate that the shank part of that tool will be about 0.500" wide. And then you are going to cut a 12 TPI thread with it. OK, I guess it could work if you take light cuts. Good luck.
I would recommend that you start your cut at the bottom of the hole and run the lathe backwards. And you need to be careful of clearances on all parts of that tool, not just under the cutting edge.
I think the OP will need to either change his design, if he can, or make a special set of taps starting with a taper tap that has only half height teeth and going, by stages, to a bottoming tap with full size teeth. I would think a minimum of three would be needed but more likely four or even five.
In any case this is going to be difficult. I expect the OP is working with steel and he needs a full depth thread for maximum strength. He did say it was for a slide hammer. An insert does not sound like a workable idea.
Thee are, of course, companies that will make custom sized taps. Here is the first one I found:
http://catalog.tapcotaps.com/request/all-categories/custom-made-taps-and-dies
I am sure there are more. I am not recommending this one or any of the others.
Pete
MGREEN
05-01-2017, 04:36 PM
O1 tool steel rod annealed.
Turn yourself a bit of live tooling with the end profiled to match and smaller
than minor diameter.
Gash some teeth then harden and hone.
Contrive some way to rotary drive it on the tool post.
Set the lathe gear train for correct pitch and use back gear for slow feed.
JoeCB
05-01-2017, 04:37 PM
Straight sides, round top? sounds like some Chinese roll formed thread. Feeling lucky? look for a big "C" clamp with that correct size screw, cut off the "nut" , machine round and use as a weld bushing.
Joe B
754
05-01-2017, 07:32 PM
I suggested single point, and have done it for 1/2. Or smaller entry hole, and made my own tool to cut it.
A bit less work than making four or five taps in my opinion..
Light cuts of course.. V thread it first to near final width..makes it easier.
larry_g
05-01-2017, 08:09 PM
https://www.protoindustrial.com/en/support/Documents/108/Proto%20108%20-%20Pullers%20(p.823-856).pdf
Looking in the Proto catalog above you will find a few items that screw onto the 5/8-12 acme slide hammers, like in the link below;
http://www.toolup.com/Proto-J4206CA-PULLER-CROSSARM-6-TON-2-W
http://www.toolup.com/Proto-J4256S-2-7-8-Inside-Hook-Jaw
Is it possible to buy one of the screw-on adapters like above and modify it? It's a lot cheaper than buying a tap, if you find one.
lg
no neat sig line
metalmagpie
05-01-2017, 08:30 PM
Joe B
The thread is from a slide hammer which is part of a Proto puller set which costs several hundred dollars. It isn't Chinese roll formed thread, that's for SURE.
metalmagpie
metalmagpie
05-01-2017, 08:34 PM
lg
no neat sig line
This project (adapting a slide hammer to Vise-Grips) doesn't justify anything like that. I have already made an adapter with 1/2-13 female threads. I have a 1/2" bolt about 18" long and I'll weld some kind of blob on it and drill a clearance hole down some kind of weight when I actually need it.
metalmagpie
metalmagpie
05-10-2017, 12:02 PM
Just a followup note in case someone is searching this forum for this issue. I took the Proto screw to my buddy's house and we looked at it on his optical comparator. It turned out to be a 60 degree thread but with the tip ground off the turning tool so that the thread had flats on both the crest and 'valley'. See:
http://nwnative.us/Grant/images/temp/protoPullerThreads.jpg
So there isn't anything all that unusual about the thread. It appears quite possible to single point it. The proprietary nature probably comes more from the 12TPI than from the thread form.
metalmagpie
