Are these DRO junk help from Electronic Experts
The DPM (Digital Panel Meter - not DRO) measures AC current to a maximum of 199.9 mA. The proximity switch outputs pulses when it detects a metallic (or magnetic) object, and may be used with a digital counter or tachometer for RPM. They serve entirely different purposes. Quality is hard to judge, but the datasheets look reasonably good so probably OK.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
There is a basic unfamiliarity with electronics expressed in the original posting. The two devices are a DPM and a proximity switch, and getting from there to a tachometer, etc., is a rather far leap.
If your goal is to make tachometers or anything else useful, then I'd suggest the most direct and useful learning path would be to buy a Arduino learning kit from someplace such as Sparkfun or Adafruit, and it will teach you step by step how to make inputs, outputs, digital outputs, read analog voltages, read counts (tachometer), etc... Your final level of understanding will allow you to make all sorts of useful stuff. The nice thing about Arduinos is that you can use the same basic skill set to make controllers, sensors, etc. Plus - the basic parts are fairly cheap and sort of like Legos...
On the other hand, if you are asking because somebody offered you a bunch of DPM and proximity switches for reallllllly cheap... then no... unless you already know what you are doing they will probably end up in a corner being a reminder of a bad decision.
Thanks Guys it all came from the Dump,never got rained on some one must have chucked just before I got there.There were 13 of those meters ,3 prox switches and 10 KB DC drives in those cast alum inclosers are they called Nema1 maybe.I brought 6 of them home but don't seem to work if had wired correct.
Originally posted by Tundra Twin Track View PostThanks Guys it all came from the Dump,never got rained on some one must have chucked just before I got there.There were 13 of those meters ,3 prox switches and 10 KB DC drives in those cast alum inclosers are they called Nema1 maybe.I brought 6 of them home but don't seem to work if had wired correct.I just need one more tool,just one!
Originally posted by wierdscience View PostMaybe post a picture or two of the KB drives,if they work they could be quite a haul.
Sorry PB not happyLast edited by Tundra Twin Track; 06-03-2017, 01:30 AM.
It may be possible to use the proximity switches and the DPMs for a tachometer. Here is a simple circuit:
Description. Here is a simple circuit that can be used as a tachometer. The circuit is basically a frequency to current converter which converts the incoming signal into a proportional current to drive the meter. The deflection on the ammeter will be proportional to the frequency of the incoming signal. For using this circuit as
You might need to do some minor surgery on the DPMs to change from 100mA to 1mA, and it may be even trickier since they are AC input. Probably not worth the trouble unless you want a learning experience. You can get a proximity sensor paired with a DMM for a tach for about ten dollars.
The KB Penta Drives are probably worth fixing. Manuals are available:
Last edited by PStechPaul; 06-03-2017, 02:27 AM.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
