Hi Group,
Newbie question here.
I have a BP clone and want to do a hole, offset to one side (making a eccentric BB for a tandem bike) in a 3" round piece of aluminum .50 thick. The hole will be drilled close to size and then I will attempt to use the boring head to finish cut the hole to a press fit size of 1.65" for a steel sleeve. The head that came with the mill is a Criterion .625 straight shank head. I have a R8 collet to fit and have a carbide tool from one of the regular boring bar sets in the wood blocks from who I'm not sure. I have checked the sharpness with the 10x loop and feel I'm OK on this part.
So my question is, how do I set this up for boring the hole drilled in the mill, keeping the same setup, after changing the tooling to bore. I see the allen wrench adjuster for 1div=.02MM where do I set the tool bit in relationship to the hole. Is It like boring on the lathe, touch off on the hole and adjust the table for depth of cut?
Do remember I'm a HSM newbie, and am self trained with your help from my questions posted here from time to time and lots of reading here and other places..
I look forward to your answers.
TX
Mr fixit for the family
Chris
TX
Chris
